dipped them in what? Hot Sauce/Salsa?
Chocolate
Ryan
I dropped and filled the trans today. Took a lot longer than I remember it did on my old truck. I did a complete drain and fill over the summer, also switched to dexron 4, just never got around to changing the filter. Not a whole lot of clutch material on the mag or in the filter. Not bad for almost 200k on the trans
Hopefully buying a set of wheels, and tires from a guy at work. My wheels are corroded really bad, and the tires are shot. $550 for the set with everything. Tires have 80% tread left. They are like the wheels pictured on this truck.
We got those exact wheels with worn out Goodyear's for about $200. I suggest checking tire shops in your area in case they have a set lying around. Your friend is going to make some $$$ with this favor. Just mho.
Don't remember where I saw it on this site but liked the idea of someone adding the lights in the rear bumper steps so I decided to do something similar. Also decided to add some interior colored floor lighting.
20141010 214538 resized
20141010 214737 resized
20141010 214612 resized
Not buying these now because I don't like how they look.
Instead Discount Tire has a bunch of rebates on Coopers right now. I really like the ATP, but it doesn't come in 6 ply just a SL or E load range. I've always bought the SL load range before, and never had a problem, but I'd like to step up to a 6ply C range this time. Only problem with that is AT³'s are the only ones in C, and they cost more than the load range E ATP. Load range E is way to overkill for me, but the cheaper cost is pulling me in.
I don't really want to spend $700 on tires that will probably dry rot before the tread is shot. Decisions decisions...
Edited by Daryl Z71
Go ahead and get a man's tire. 15k on my ATP's and no flats yet. Had 5 flats on one tire with the old goodyears.
I tow my 20 foot jonboat (maybe 500 lbs total, and I can pick up the tongue), and rarely anything else. The 10 ply tires corner better and are a lot tougher. I run about 37 front and 33 rear to get the right contact. Plus if you go off road you can actually air them down. I put a little extra air in the back if I'm hauling much. Most people around where I'm from wouldn't even consider running anything less than a 10 ply tire.
How much can you get the ATP's for? I payed $185 I think. The dry traction isn't the best and they've gotten louder but I still would buy them again at that price.
Do yours bulge bad at all running 37psi? My current AT³'s are 10 ply, and they bulge really bad at 40psi. I think it's because their junk, and worn out though.
With the instant rebate, and Visa gift card they'll end up being $628.00
37 in the front:
2D2CD78D-1A1F-4D41-825F-05891B7ABDC6_zps
33 in the back:
4347A184-6464-46D7-ADB8-03353BEA6153_zps
I don't pay much attention to the way the sidewalls look. I just go off of the "chalk test". If I drive somewhere and I can see there is still gravel dust on part of the tread I let out air. And these pressures seem to give good contact on my pickup.
I found some dirty dirt roads this weekend.
Edited by kstruckcountry
    1981dustin
    1981dustin
  • Who's Online   1 Member, 0 Anonymous, 1,539 Guests (See full list)
