Went and picked up our Christmas tree yesterday. Used my truck of course.
used my damn vee dub! Lol
Das Auto
Sent while in 'Murica...
You would be surprised to see diesel cars hauling campers and boats around here. And they use the most odd hitches I have ever seen, almost would think they could tow all that weight.
Daryl, please update your build thread when you do the tie rod ends.
I would like like to do this plus the ball joints in the spring.
Started my truck this morning and noted the voltmeter is noticeably pushing more voltage then normal. So I think I may have a battery drain. That would explain the air bag light being on, which is what I thought in the first place. Since I've read more then a few threads about the radio being shorted out causing a battery drain, I've temporarily pulled the radio fuse to see what happens. I currently don't have a way to test for battery drain so I'm stuck with trial and error troubleshooting for now.
Ordered two new MOOG inner tie rod ends, and a reverse bulb socket for the truck.
I've not done the inner tie rods before but the outer tie rods are just like what we have at work. It seriously takes me longer to get my tools out of the toolbox as it does to change the outers.
Changed my antenna to a bullet. Direct from china for $7. So far so good with reception but i mostly listen to harddrive or XM.
I love the look.
http://www.ebay.com/itm/Aerial-Antenna-2-8-Black-Carbon-Fiber-Bullet-Ultra-Short-Fit-Dodge-Chevrolet-/221570461228?pt=Motors_Car_Truck_Parts_Accessories&hash=item3396a0ee2c&vxp=mtr
To fit on my truck tho i did have to use an adapter which i allready had from my last truck.
Edited by GasHog369
Haulin my new toy 2012 yfz450f
But you arent driving
wonder what speed those woofers were to travel in a front end collision???
Disregard, how do I go from this to.watching Mythbusters do a test for this thing is beyond me, but at 45 mph, it won't feel good but that is a fairly slow speed.
Edited by Carder
Front face camera chris... This quads awesome does wheelies every time you take off lmao now I have an extra push to finish my trailer
It doesnt reverse the image to make it correct? I understand t
It was the front facing camera. But it looks like left shoulder is towards the center.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
