Never driven a truck with 3.08s. Is it really sluggish? It would be the equivalent of 3.73's in my 02 with 35's
Sent while in 'Murica...
It's not bad. Still plenty good for around town and as I just learned decent enough for desert blasting.
Reason I steered away is because they are only rated to tow 6600 lbs which is good enough for me but i know towing with the setup I just explained (35's and 3.73's) it felt like the truck was barely moving with a 5000 lb. load behind it. I wish I had 3.73's in this new '14, supposedly rated to tow like almost 12k pounds with them
Almost hit a deer. Got an awesome video of it. Posted on FB
Ryan
Ryan
I saw that, it was nuts!
Washed it since I have a 3 day weekend and no rain/snow in the outlook
Ryan
Ryan
Going to rain here tonight and tomorrow. Mine is going in the garage tonight.
I'm fat and lazy. I dont wash my own truck. I make my ex do it.
Managed to break the car wash the first time I took this truck through it [emoji23]
Maybe because it knew you were doin your ol' truck wrong by letting those things slap and scratch up your new ride!
Brand new truck: time to install a tool box in the bed. Did that after work today.
Hey somebody stole half of your toolbox.
WTF are you thinking? Hand wash 2 bucket method!
Ryan
    Frank V
    Frank V
  • Who's Online   5 Members, 0 Anonymous, 1,209 Guests (See full list)
