If it goes like the last truck I have 4 more years
Ryan
Trade up for a second minivan? :lol:
Depending on engine siZe maybe a 2500HD sure call it a "minivan"
Ryan
Pulled the cabin air filter out & about 2 trees worth of debris came with it. I'll replace later but I think my blower fan might work/sound better. Also found out the dual battery setup wasn't working since the mega fuse was blown.
Changed fog light
The drivers side has really faded over time 761d7e814dfbff7aa278bfcb0bf33962.jpg
These are secured much better than the gmt800's which used to vibrate pretty good. These have a bracket holding in place
Also drained my catch can
Ryan
Drove to the Columbia mall today, wish I had a diesel I would have rolled some coal all over that little punk in the mustang that wouldn't let me over, and his window was down too.
Bout to start cleaning the HC. Yes, it's 30 degrees and yes I had to thaw the hose with a forced air heater but I have some down time for a few hours and I'll man through it. Besides, I can't stand seeing her so dirty
I got my Westin Quadrant LED aux lights today. They came with the harness and everything. Nice lookin' lights. Metal housings. Seem sturdy as hell.
...and ordered a set of Steelcraft 5" oval nerf bars.
Edited by patriot
I almost just spit my coffee on the computer when I seen this. I swear its the same exact color. I have been hearing a lot about catch cans but not really looked into the subject. Looks like I have some reading to do.
    Frank V
    Frank V
  • Who's Online   5 Members, 0 Anonymous, 1,209 Guests (See full list)
