I've never had an issue with seized plugs when I put a good coat of antiseize on them. I actually have more issues with getting the boots off the spark plug end, and yes, I even coat the crap out of them with dielectric
Same here.
I had an 04 Z71 that I traded with 180K miles mostly HWY miles. I called an auto repair owner friend of mine about changing the plugs at 100K miles. He said the ones he'd were changing at his place still looked good. Didn't mention anything about problems getting them out. He said change them when the service engine light comes on. I picked up a set carried them with me just in case. Finally gave them away. Still in there when traded at 180K. I must add that I travel a lot that was just a little over three years, if that makes a differents.
Edited by KARNUT
I wouldn't say they looked good when I took them out. Also confused on which plug wires to get rock auto shows two different acdelco wires for my truck.
Some have a 90° plain rubber boot, and others have a (just guessing) 30° bend with a metal shield around the boot.
Also, there was an "old style" coil I guess. I thought they were all the same. Haven't worked on many LS engines, so I couldn't tell ya.
Ls are straight or 30° i think
Usually they tell you to match the number on your coil packs to the wires you need...
Picked up a 8'x 16' enclosed trailer from my wife's uncle, this weekend is moving weekend..... Not gonna be very much fun...
Ordered myself one of those... however not for anywhere near that price. Normally I would build from scratch... I do have a set of LS3 heads and the complete manifold from one of these crates I snagged with 3000 miles on them for $300 but I basically would have had to buy a new block, put together a rotating assembly... dress it... etc. Finding a used 6.2 is not easy... and then rebuild it. My time is worth a lot more than the cost of the crate plus they say 2 years warranty. I might crack it open and take some measurements before I run it.
Sent from my SM-G900W8 using Tapatalk
Edited by 1994Vmax
Started the redo of my garage floor
Ryan
I'm wanting a 525 version whenever/if the LS1 in the Z starts to give up. Going be years, especially if I jump ship to another job. Edited by SnakeEyes
Wish I had a floor to paint. Mine is dirt.
Lots of fun working on things in there, especially small parts. They warp instantly to another dimension, never to be found again .... until you spend money on a replacement. Then, they suddenly appear. Got to concrete that floor some day. It's at the end of a long, LONG list of things that need fixing around here. It never ends ...
The shipping crate parts I got from a local factory help. Wish I had 4 more of them - they fit perfect in here. Of course, parts find their way into the cracks ...
House%20property%20barn%207-18-2012%2030
SnakeEyes, on 01 Jul 2016 - 08:46 AM, said:SnakeEyes, on 01 Jul 2016 - 08:46 AM, said:
I thought about the 525 but for a truck with an automatic the cam has too much duration and coupled with the 110 degree LSA to drive nice at low speeds. Easily need a 3200+ rpm stall for that. This hot cam is pretty mild in comparison and should have pretty good street manners... If GM's advertised power curves are at all accurate the torque should be pretty acceptable to run a 2500 stall. It's somewhat important as even though this truck is a toy I honestly have a 7.5' Western Plow I will run on it in the winter to clean my yard out. I already have 456 gears in it and through a built 4L60E it should be good. The truck is a 1990 GMC K5 Jimmy.... a rust free loaded little gem I got in the spring. The 350 in it runs nice and smooth.... but smokes like holy hell at 3000+ rpm and has a fluttery knocking sound that would make me think a broken piston. Has good oil pressure and doesn't miss... Don't care what's actually wrong with it though now.... it can go to the metal bin lol. The LS3 should be on my shop floor in about 2 weeks.
For fun I found a Youtube video of a Nova running a stick behind this engine and with nothing more than headers and tuning they laid down 490 whp. Oddly enough the guy I bought this through tunes at the dealership on the side and said a customers 55 Belair they dropped one of these in with a stick and headers also made 490 whp...... pretty impressive. With bigger tires and through an auto I don't expect much more than 400 whp with mine.
Edited by 1994Vmax
I wonder how much money it would take to get similar HP and TQ out of a 5.3L...
    • I just brought home a 2020 GMC 1500 Denali.  She has 53K miles on her and I want to change out the fluids over the next few weeks.  I see the diff covers don't have drain plugs.  Any suggestions where I can pick up front and rear diff covers with drain plugs?   Thanks,   Bob
    • Well, the dealership got the compressor and installed it. Air at the vents seems nice and cold as it should be. The service manager said the repair has a two year warranty and unlimited mileage. Hopefully I don't have to use it. The dealership i went to was one where I bought my 2014 half ton silverado. In 10 years and 168k miles on the truck anything I needed done and two small recalls they were always very good to me. Not a huge dealer either. I think they treat people well because they want you to come back. I have dealt with a different dealer that was too big to care about an individual. Just my two cents.
    • Hi All, I operate my 2021 3500 SLT most of the time with the tailgate off and in a crate because I have a slide-in camper. However, at least once a year, I take the camper off and put the tailgate back on. Recently I installed the tailgate, but had a hard time getting the connector bail to swing to the fully latched position. The connector seems to fully seat, and everything works, but the bail doesn’t swing to fully latched position.  It swings almost there but stops and I am afraid to push it any harder.    Does anyone have any advice on cleaning or lubrication or anything else I should be doing?  i know how to properly operate the connector. During the time the tailgate and connector are off, i have a double plastic bag over the truck connector secured with rubber bands to keep it clean, but it still had some dust in it this time when I blew it out with compressed air. I didn’t want to spray it with anything other than air without doing some research. Thanks.
    • There are a lot of spammer's that do that, quote something and add some commentary to make it seem legit, but modify the quoted text a bunch making sure when posted it's long enough to be "click to expand", and either immediately insert a spam link, or come back after some time and edit it to add the spam link.
    • Hello @jaszr2 Do you have a link for the item? I put a replacement bumper on my truck and consequently had to relocate the shutters. I studied on them a while, and figured if you left a couple key blades, you could get most of the airflow with probably no throwing codes.
