Why don't you just post up a link lol #shamelessthreadplugs
Ryan
Edited by RyanbabZ71
Ryan
Shameless plug would be providing a link. But i think you can use some of this stuff on the camaro
Changed my spark plugs , AC belt and serpentine belt last night. Who decided stretch fit belts are a better option I would like to punch in the face. Also do you guys change the short plug wires at the same time or not?
Broke the key to my truck. Was not close to a dealer. So I risked putting the broken piece into the ignition and the rest of my key in as well and I was able to get the truck started so that I could at least get home where I had a spare key. Got home and turns out that the spare key I had was not to my truck but to the Impala I traded in. I gave the spare key to my truck to the dealer thinking it was for the impala. :idiot:
Drove over to the dealer, had a new key cut, but of course it needed to be programmed to the truck and for the 2011+ models (I believe it is 2011+) it requires the GM Tech II to program a new key to the vehicle when you don't have another chipped key already programmed for it available. Add to that the broken piece is stuck in the ignition switch (I spent several hours trying to pull it out with a pic set) And well, the dealer gets to handle it from here.
:banghead:
Oh well. Lesson learned. They are going to look into why the DPF is going into regen every 90-130 miles vs the 400+ I should be seeing. (It says in the owners manual I should see a regen occur for every tank of fuel) I'm guessing it has to do with the bloody DEF system like some on here have indicated. Thankfully GM extended the emissions system warranty on the Diesels because of frequent emission system issues since they started throwing on the DEF crap.
I always change the wires with the plugs.
Doesn't your truck have a tensioner for the A/C belt?
In 09 they stop using the tensioner.
What do you guys recommend for wires?
Edited by NEFisher11
I have often wondered and never looked on the trucks without the tensioner on them.... do they still have the bolt holes for it on the bracket? If they do well I know what I would do lol.
Sent from my SM-G900W8 using Tapatalk
Figures. I use Acdelco.
Have always had bad luck with Bosch electrical anything, I agree with Daryl. ACDelco wires or even a set of MSD wires
Sent from my SM-N900V using Tapatalk
I tired Bosch plugs in the Ex's Grand Prix once. Ended up changing them back out because it kept fouling them.
Not plugs. I use AC Delco plugs, i use Bosch wires
Had a misfire due to the Bosch wires so swapped out for Delco wires and NGK Iridium plugs, didn't have an issue till the day I sold the truck. I run NGK Iridium in everything I own with a motor... which isn't much [emoji23]
I know, mine was just an example.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
