I've never had an issue with seized plugs when I put a good coat of antiseize on them. I actually have more issues with getting the boots off the spark plug end, and yes, I even coat the crap out of them with dielectric
Sent from my SM-N900V using Tapatalk
Same here.
I had an 04 Z71 that I traded with 180K miles mostly HWY miles. I called an auto repair owner friend of mine about changing the plugs at 100K miles. He said the ones he'd were changing at his place still looked good. Didn't mention anything about problems getting them out. He said change them when the service engine light comes on. I picked up a set carried them with me just in case. Finally gave them away. Still in there when traded at 180K. I must add that I travel a lot that was just a little over three years, if that makes a differents.
Edited by KARNUT
I wouldn't say they looked good when I took them out. Also confused on which plug wires to get rock auto shows two different acdelco wires for my truck.
Some have a 90° plain rubber boot, and others have a (just guessing) 30° bend with a metal shield around the boot.
Also, there was an "old style" coil I guess. I thought they were all the same. Haven't worked on many LS engines, so I couldn't tell ya.
Ls are straight or 30° i think
Usually they tell you to match the number on your coil packs to the wires you need...
Picked up a 8'x 16' enclosed trailer from my wife's uncle, this weekend is moving weekend..... Not gonna be very much fun...
Ordered myself one of those... however not for anywhere near that price. Normally I would build from scratch... I do have a set of LS3 heads and the complete manifold from one of these crates I snagged with 3000 miles on them for $300 but I basically would have had to buy a new block, put together a rotating assembly... dress it... etc. Finding a used 6.2 is not easy... and then rebuild it. My time is worth a lot more than the cost of the crate plus they say 2 years warranty. I might crack it open and take some measurements before I run it.
Sent from my SM-G900W8 using Tapatalk
Edited by 1994Vmax
Started the redo of my garage floor
Ryan
I'm wanting a 525 version whenever/if the LS1 in the Z starts to give up. Going be years, especially if I jump ship to another job. Edited by SnakeEyes
Wish I had a floor to paint. Mine is dirt.
Lots of fun working on things in there, especially small parts. They warp instantly to another dimension, never to be found again .... until you spend money on a replacement. Then, they suddenly appear. Got to concrete that floor some day. It's at the end of a long, LONG list of things that need fixing around here. It never ends ...
The shipping crate parts I got from a local factory help. Wish I had 4 more of them - they fit perfect in here. Of course, parts find their way into the cracks ...
House%20property%20barn%207-18-2012%2030
SnakeEyes, on 01 Jul 2016 - 08:46 AM, said:SnakeEyes, on 01 Jul 2016 - 08:46 AM, said:
I thought about the 525 but for a truck with an automatic the cam has too much duration and coupled with the 110 degree LSA to drive nice at low speeds. Easily need a 3200+ rpm stall for that. This hot cam is pretty mild in comparison and should have pretty good street manners... If GM's advertised power curves are at all accurate the torque should be pretty acceptable to run a 2500 stall. It's somewhat important as even though this truck is a toy I honestly have a 7.5' Western Plow I will run on it in the winter to clean my yard out. I already have 456 gears in it and through a built 4L60E it should be good. The truck is a 1990 GMC K5 Jimmy.... a rust free loaded little gem I got in the spring. The 350 in it runs nice and smooth.... but smokes like holy hell at 3000+ rpm and has a fluttery knocking sound that would make me think a broken piston. Has good oil pressure and doesn't miss... Don't care what's actually wrong with it though now.... it can go to the metal bin lol. The LS3 should be on my shop floor in about 2 weeks.
For fun I found a Youtube video of a Nova running a stick behind this engine and with nothing more than headers and tuning they laid down 490 whp. Oddly enough the guy I bought this through tunes at the dealership on the side and said a customers 55 Belair they dropped one of these in with a stick and headers also made 490 whp...... pretty impressive. With bigger tires and through an auto I don't expect much more than 400 whp with mine.
Edited by 1994Vmax
I wonder how much money it would take to get similar HP and TQ out of a 5.3L...
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,264 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
