Just cleaned up this thread for the last time. Time to start handing out suspensions.
Sent from my SM-G925V using Tapatalk
They do that stuff day in and day out. They should be able to get it out of there pretty quick, although I have trust issues when it comes to stuff like that. If it were mine, I'd probably remove the part that was to be painted. Should save on labor too.
I have a new tailgate handle and bezel (chrome is going on, black is coming off, and the bezel of the chrome handle is getting painted Deep Ocean Blue), so the only guy touching the tailgate on the truck is Yours Truly.
I was just wondering if I should remove the chrome handle. It looks like it's fairly securely attached, so maybe I should leave well enough alone.
Thank you for your suggestions though. In my older and less dumb age I've learned those older than me have buckets of know how to share. :thumbs:
Edited by CadillacLuke24
I'd probably leave the handle. Really no reason to remove it, since you're only painting the bezel.
Polished my turd up for woodward dream cruise. IMG_20160818_134233.jpgIMG_20160818_134140.jpg
Just cleaned up this thread for the last time. Time to start handing out spankings.
Fixed it for ya.
I'd paint it all myself but that's just me
I would, but:
A) My rattlecan skills are still improving
B) The bodyshop around here comes highly recommended
and C) Haven't found Deep Ocean Blue yet....hmmm should go to napa or the dealer and get some.
I want it to match the quality of the truck (or better, as I've heard indy shops can do). Can I do that myself? No.
On that note, once I get funds, I'll take the whole assembly down and tell them to have at it. Can't wait to get it on the truck :drool:
VLEDS really knows how to take care of a customer, ordered my HID's Tuesday late afternoon (eastern time) and they came Thursday, now that's fast! Just waiting to get my truck back from the body shop now so I can install them. Can't wait because my headlights are lacking some output
Putting HIDs on our '86 Grand Marquis was the best thing I ever did. They've been holding up great too - been on there almost 3 years so far without a single issue. Huge difference from sealed beams. Probably won't be as dramatic a change with a modern vehicle, but an improvement nonetheless.
This is high and low on at the same time. High is still the OEM sealed beam - it looks orange next to the 6k HID.
I had a 98 Grand Prix GT a few years ago. It needed HID's, the factory lights were horrible.
I had DDM tuning ones on my highs, lows, and fogs in my 02. For the price they were awesome and lasted 2 years, bet they are still on there honestly. I could really light up the night especially since they weren't adjusted correctly [emoji16]
Have to order rear brakes. While rotating tires a few wks ago noticed they were pretty worn. Thought they would hold up but started screeching time to replace. Going EBC with slotted rotors
Ryan
    jaszr2
    jaszr2
  • Who's Online   6 Members, 0 Anonymous, 550 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
