LOL that's a new one, never heard Wyoming compared to Kansas
At least Wyoming has trees! :lol: I'd say ND is the 2nd Kansas, except at night you are much more likely to get antlers through your face on the highway. You cant tell the difference between eastern Colorado, western Kansas, most of Nebraska, Western OK, northern SD and most of ND(again, except for being overrun with wildlife). Of course, it is called the great plains for a reason!
Just be glad you got something that looks much better than the GMT-900s. Wait. I mean!!!
It's sad, I still haven't learned the platform names. I have an 09HD I like the look of my 09HD much better than the 06HD I had. I hated that Avalanche front end look. Made me miss the front end on my '01HD, seeing my 01HD the other day made me miss it too. Maybe I should have told them I was going to have to move my boat and haul a couple pallets of concrete mix around. I wonder what putting either on this will do to it lol
99-early 07 is the gmt800 platform, late 07- 13 (15 for HD's) are gmt900's (your new truck) and then from 14- 17 are the k2's. Next platform is the T1XX platform I believe
Yeah sounds about right. I still have to look it up every time, my memory is pretty bad.
You should come moderate the k2 section for a week, see what I have to deal with [emoji28]
Edited by rdnckhntr94
You should come moderate the k2 section for a week, see what I have to deal with [emoji16]
I don't want to moderate anything. I'm too much of an a-hole with too little patience. It wouldn't be pretty.
GOOD GRIEF, WOMAN! I'd hate to piss you off!!
Probably a good idea lmao
Sent from my SM-G925V using Tapatalk
Did the paperwork on my new gun yesterday and changed my air filter today. Need to process some orders today as well.
This is old and new. Old one was in there for 42 months and over 70,000 miles in a smoggy, dusty, agricultural area.
Looks like the filter for the 6.6 with a giant rubber reducer.
Edited by Chevor
Got all 4 of my wheels in finally and my lug nut kit. Pick up the truck tomorrow from the body shop then straight to my tire shop to mount and balance these wheels before the weekend is here since I'll be out of town in PA with my lady
In PA!?!?
In PA!?!?
Yeah man, I'll be at the York county Fair Saturday evening for a concert and then we're going to Hershey Park Sunday and leaving from there. I don't know PA at all, where are you located at?
Sounds fun. I'm pretty far from York and Hersey actually. I'm 60 miles from Harrisburg.
Ah gotcha. Too bad, would of been a good time to meet up!
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
