Installed the new brake rotors, and did an oil change. I picked up a new gasket and gear oil for the rear differential, but didn't get to that today.c3f0b6007415dbaf5a139093db3c7af9.jpgf61da05f49704b81987eac766cbe67c9.jpg
:thumbs:
WTF! Has it been changed before?
I've seen posts of guys having to get towed back from test drives because the factory forgot to fill.
Whoops?
Edited by SnakeEyes
Hauling with big red 2013 LGH. Much more driveable truck than LMM
Only have one wd hitch arm on, electrical box in way on other side....not the first time one of these factories have mounted something in the way.
Hooks on this thing are huge.
don't have a clue if it has been or not. 2005 truck. Bought it in 2011 and so far drove it 60k miles. Never checked fluid before. It has 125k miles on it.
Edited by DareDog
Whoops?
lmao yeah just a slight mistake there
Good God man, clean that thing! :lol:
I hit it with some Amsoil Brake Cleaner
Went in for Transmission fluid change.
832,875 miles on truck
Unhooked from a trailer last night, set the adapter plug on the bumper, forgot it was there and opened the tailgate to put my hitch in the bed. Got a nice little dent now. Paintless dent guy just looked at it over lunch and said no biggie. Thank God, I was sick...
Also, let truck sit outside this week, driving dually.....was complete last time I checked. About 2 weeks ago.
Damn Red squirrels.
GM wanted $162 from new hood insulation. Dad had his 2013 hit also. Nowhere near as bad. The 2013 new hood insulation is $65. Just reused his old one.
Put a good spraying of Squirrel Stop, mostly peppermint oil, on a engine bays.
crazy!!! almost to a 1,000,000!!
Looks like someone forgot to tighten the pan bolts, or cooler line - left a nice puddle in the lot there ... :noway:
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
