Maybe, although sometimes I think the roads I travel on in NJ are better than the constantly under construction ones here in Orlando. I've known a few people that have blown out tires or bent rims because of all the construction we have always going on. Granted they drive cars and some of them were lowered so there's that too. I also don't really slow down for stuff unless the vehicle in front of me forces me to.
Just got back from installing the dash cam I bought last week. Ran the power cord along the top of the windshield tucked into the headliner where it will hopefully stay, then down the pillar, through the fuse panel opening, and behind the steering column panel. That should do until I get around to getting or making a hard wire kit. Think I messed up the top tint strip a little. That or I forgot to take the plastic off the suction cup. Oh well. Took 15 minutes and I found out I'm missing one of the screws on the bottom steering panel.
MA roads are 10x worse than NJ's. My road hasn't been paved since the late 50's or early 60's. It's been patched 10,000 times since. If they turned it to dirt, it would be an improvement ... seriously!
I replaced my keyless entry / remote start unit, (Audiovox). For the last week it had been randomly refusing to start or lock/unlock. I had to use their override button to drive the truck. I got a new CompuStar unit installed.
Edited by txab
Took over 500 pounds of gear out of back of truck. Hitches, tools, extra fluids. Considering retiring the 2010 from commercial duty.
Truck is showing CEL at startup. Edge is showing PO401 - EGR insufficient flow, and PO674 - #4 glow plug circuit.
Recently P2155 -injector supply group D circut has showed up a few times. And hauling in 100 degree heat was seeing dreaded PO087 - low rail pressure code.
Got my new tailgate handle in the mail. Thanks to the forum I know the torque specs for the handle bolts :thumbs:
Now to get it painted. Hoping that the dealer can do a nice job for double digit prices.
Just MO, but I'd find a body shop before I let any dealer paint anything ... unless you don't care how it looks.
Tires came in today and they should be mounted after the alignment at 3:30. #Christmasinjuly
Sent from my SM-G360V using Tapatalk
Pics or it never happened. [emoji1]
It's only 2:30 here in Arizona! An hour away from opening the presents one by one.[emoji16]
Okay, then pics by 11pm eastern time tonight or it never happened. [emoji1]
  • Like 3
That's a thing of beauty! Lots of zeros on the end of that bill, I bet ... :noway:
Changed fuel filter.
Let someone else tighten fuel bleeder screw last time......
Buying new bleeder screw.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,254 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
