Been waiting for this day since I bought the truck - knew it was just a matter of time.
My suspicion of an issue when I had no comm with my scan tool months ago proved correct today. Went to get a sticker, failed for monitors not run. Haven't touched battery in YEARS, hasn't run low in over a year, and haven't had, or cleared any codes.
Yay! Get to troubleshoot 15,000 miles of OBD-II wiring today! :banghead::banghead::banghead:
No "wire" troubleshooting will get you anywhere in finding out why a readiness monitor isn't running.
Brought the old girl home today. My parents have had it for a few weeks, while they are doing some reno's. It's been to the dump a few times now, definitely needs a bath...
Was trying to figure out why I couldn't download any PIDs, but that was solved by selecting "Global" instead of "Domestic" on my scan tool.
Also, the battery wasn't touched, and there were no codes to clear. How the hell can a monitor change state by itself? Figured that to be a wiring issue somewhere.
We'll see if I can get them to run since disconnecting the battery for an hour. If not, I'll take my chances with the black "R".
Edited by Jsdirt
I changed out my idler and tensioner pulley. They weren't bad, but the idler was getting "gritty". I did the AC pulley last year. Better to spend a few bucks now and change it than need a pulley and a belt on the side of the road. Over 137,xxx miles on the originals. Dayco belts are still looking good after 4 years.
Edited by kstruckcountry
Wow that's a damn good run there! Nobody gets close to that up here in the winter salt & sand.
Mine were starting to squeak at 60 - 70k. I removed the seals, flushed them out, and packed them full of corn head grease. Replaced the bearing and belt on the A/C compressor too. That one spun too fast for the corn head grease - sounded worse afterward, so I junked it. Tiny little thing. It's a wonder it makes it out of the dealership. Main belt is still OEM. At 86,5xx now.
They probably would have made it quite a while longer, but I go on a lot of trips where I'm a long way from spare parts. They'll go in the box for spares.
I changed out my idler when I swapped motors, and tore apart the tensioner and greased it. The tensioner was the one off the newer engine I swapped in. Had 75k miles on it and still spun nicely.
Took my truck into the back country of Colorado.
Sent from my SAMSUNG-SM-G930A using Tapatalk
  • Like 8
Welcome to Colorado! Hope the wildfires don't bother ya.
Fires haven't bothered us so far.
The family has been coming to Crested Butte for about 30 years
That is a brochure quality picture! Nice dude!
  • Like 4
Drove 70 miles today ... and I STILL can't get a damn drive cycle to complete!!
THANKS GENERAL MOTORS, you bunch of *#&%$( A$*&&@^&& !!!!!!!!!!!!!!!!!!!!! :banghead::mad::banghead::mad::banghead::mad:
I finally ordered new tires at Costco today, unfortunately i missed the $70 discount by a week or so!! Ended up totalling $897 and they should be in by early next week.
Michelin defender ltx ms in P265/70/17
Sent from my SM-G360V using Tapatalk
All I did was drive it to work. But I love this pos.
Feels like a new truck after the new trans and new pioneer head unit.
C1666BE9-8E1A-41D7-912F-C90EA36CE42A_zps
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
