What do you own?
wurgs
  • Replies 190
I can assure you that the MK25 is a LOT better pistol as a SA. DA really does suck.
But ...
Would a round chambered and the hammer de-cocked (like the 226) be just as safe as a chambered round with a safety engaged (like on a 1911)?
But ...
Yes. There is a firing pin block similar to a Series 80 1911. The MK25 is just a improved P226, there aren't any operational differences. Almost all Sigs use the DA/SA trigger and I've yet to shoot a better DA/SA pistol than a Sig.
Kilo, that DE grip looks awesome! Is it a carry gun or a weekend shooter?
Thanks for the info. Mike. I'm no expert and learn something new all the time. Its great to pick the minds of other users.
On an unrelated note ...
Impulse buy of the week ...
God endowed me with lobster claws. So I didn't like the Shield because the grip was too narrow and too skinny. After 2 or 3 rounds it would walk in my palm making me stop and reset my grip. It was like holding a skinny deck of cards. I installed a Hogue sleeve and it helped, but in the end, I passed it on to some one else.
A friend let me run a few rounds through his XDs45. It was a great gun and felt great in my hands. But the reality of it was all that umph just made it a little hard to quickly empty a mag in a panic situation and stay on target. I mean isn't that the reason for an EDC weapon? Or is it to make "look at me" posts on the internet?
So I waited for the 9mm version. Seen a few in the $700 - $800 range ... pass.
Went to a local, small gun show and guess what I found!
The XDs9 has a much bigger grip ... a tad bit thicker than the Shield and much wider. Much easier to grip. 7 rounds went by amazingly fast ... Need more than the supplied two. I ordered a couple 9 rounders.
I ran ~50 rounds of 115g FMJ and never once did it hiccup. Target picture was easy to acquire and maintain. And getting back on target after firing a round was very easy.
At 10 yards I was able to group two full mags (14 rounds) in a 6" circle.
Trigger was very XDm-ish.
The only negatives I can come up with is that the slide kept rubbing on the Webb g of my hand between my thumb and fore finger. I didn't get bit, but there is a red spot where it rubbed it.
Second is I had difficulty dropping a spent mag. My grip draped below the bottom of the guns grip and kept gravity from doing its job. I had to release my shooting grip in order to replenish the guns appetite. The 9 round mags come with an extension. I'm thinking that extra inch will make all the difference.
For me, the Sig938 for me is a much better EDC platform. But I also like 1911s ... all of them.
This a great gun and at $500 price point is a great option. Unlike the Shield, I don't have buyers remorse on the XDs.
Thanks!
My Mk25 is just a weekend/"wanted to have it" piece. I carry a P229 on duty and a Glock 27 off duty.
Add a Short Reset Trigger (SRT) to your Sig DA/SA and you'll really be happy.
  • 1 month later...
Sold my 1938 Mosin to my younger brother but picked up Savage model 16 FCSS in 300 wsm with a Bushnell Elite 4200 4-16x50 scope on it.
Hand Guns:
Glock G19 9mm
Ruger LC380
Walther P22
Rifles:
Remington 750 30-06
Ruger 10/22
Shotguns:
Beretta 682
Beretta 303
Remington 11-87
Remington 870 Home Defense
Remington 870 Express (20ga)
Remington 870 Wingmaster
I have been shooting competitive clay targets since i was 8 so I stared our with the 20ga 870 then moved to the 11-87, then on to the Beretta 303, and my current competition gun is the Beretta 682, which I have been thinking about selling.
It was my birthday Friday and I had $143 credit at bass pro shops and Remington has a $30 rebate going....so I have an 870 express tactical on order. Should be in either tomorrow or the beginning of next week.
Here is my current setup:
Handguns:
Para-Ordnance PT10-45
S&W MP40c
S&W Shield 40
Walther P22 (for the wife)
Long guns:
Savage 10FP setup as a tactical rifle
DPMS LR-308
S&W MP15
Double Star AR-15
S&W MP-22
Remington 870 Tactical Express
Benelli Nova pump
Tristar Raptor
Next up I am on the hunt for a Springfield M1A SOCOM as my next rifle.
    • I can only guess as well that something was clicked on that brought you to the half ton choices by accident. By all means try again and chose the 3500 and sort out that its the cab and box configuration you want and choose four wheel drive ( rather obvious to have a transfer case ) and to make sure the dually isn't chosen. I find or at least did a couple of years ago when I was sifting through the options that it would sometimes jump ahead after choosing the series of truck and in this case 3500 and skip some of the other initial configuration choices and have to watch the heading bar and sometimes back up by choosing the first in the series of option break downs. I think sometimes the computer will remember items that were last chosen and skip over the first part. Anyway go through it all and depending on the trim level chosen and I think the LT is one that may fall into that where the option of having the 4 high auto transfer case can be chosen, where as a High Country doesn't show that option as it just comes with the fancier ( not necessarily better though in terms of potential problems ) transfer case but for sure both transfer case choices are equipped with high and low range in the HD truck segment. Like Newdude said who works at a dealership, its the half tons that are the ones that will come with the single speed unless certain options or trim levels are chosen that add the two speed transfer case but as your looking at an HD, you don't have to worry about that hot mess.    One item that at least didn't show up and not sure if it does yet or not in the HD options on the manufactures pubic website is the upfitter in cab switch option if one is desiring that. Unfortunately its not wired in at the factory but the panel with the switches is on the dash but the wiring harness to be installed gets tossed under the rear seat to be installed by whomever after the fact to complete the installation.
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
