How do the mirror chrome caps go on?
The OEM caps have three tabs on the bottom that lock into a mating surface on the bottom of the mirror housing, and the top of the cap has a lip that fits into the edge of the mirror facing. When removing the caps, you will probably break one, if not all, of the tabs off.
Bottom edge, in the middle there is a clip that is the hardest to get released, start there with a whale bone or plastic pry bar (almost like a knife type). Take a good look at the new caps to see where the three clips are on the bottom edge.
Thanks Everyone! So how does everyone feel about the chrome covers?
My truck came with the chrome mirror caps and door handles...I liked them until I saw color-matched mirror caps and door handles. I couldn't get a set of caps and handles quick enough then.
I was thinking about going that rout. Where can you get the color matched ones? Do I have to have them painted?
Or do you want to sell your chrome ones?
Sold my chrome ones a long time ago. Check the classifieds here or Ebay for the handles and caps. When searching Ebay for them, don't limit your search to Sierra or Silverado trucks. Include Tahoe, Yukon, Suburban, etc as the handles are the same on all of them. You should be able to get them from the dealer also.
When I changed my caps out. I pulled the top and bottom of the mirror assembly off. Made it easier to get to those easy to break tabs. Fold the mirror in and gently pull both the top and bottom pieces at the same time. Mine popped right off. Simple to change out the cap and pop them right back on. I believe it took me 10 minutes to do both mirrors. The 2 pieces they show in the picture above the cover and the housing are what I am talking about removing at the same time.
Now I need to decide between chrome or red? Any body know what the color ones cost at the dealer?
Send rich (msdale) a pm on a price. I had to buy two sets of silver birch and they were about $80 for a pair if I remember right
Ryan
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
