Debadge or Plasti-dip?
Oreilly autoparts
Www.dipyourcar.com
Ryan
Oreilly autoparts
Www.dipyourcar.com
Ryan
  • Replies 57
I like it, but you should consider ditching the rest of the chrome if you are gonna black out other parts.
Agree, maybe get some black steps or line x them. :thumbs:
I agree with the above. Pick a theme and stick with it. All of the different finishes are a bit distracting on an otherwise good looking truck.
I am working on it. As for the steps, plasti-dip, get them line-x'd, or should i just get some new black one?
Plasti dip probably won't hold up long on steps, but line x would. I would look into some N Fabs or Go Rhinos in black, best looking step IMO.
I would also consider some wheel house or wheel well liners in the back as well. Noticed on your photo link at the bottom that the rear side shot img3859gi.jpg
shows a lot of light colored paint and dark frame. Will also help when you're out wheelin'. I got a rock stuck between the wheel well and rear quarter on my '07 causing an outward dimple. Liners should eliminate the possibility.
Would you do liners, or have the wells line x'd?
I think that both would look good and be effective. Line X would probably be better for long term rust protection, but liners would cover both the bed and frame and after a while the frame ain't too pretty. With a truck as high as your's I guess I would do the liners just because you can see light between the bed and frame from the other side of the truck at the right angle and that drove me nuts on my last truck until I put in the liners. Obviously I don't do much off-roading in my current truck, I'm sure those that do will have some preference as well
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
