Stupid Stacks
doverarjim
I was wincing the entire time I helped my buddy put stacks on his. I think I convinced him to at least go back to a single.
  • Replies 120
Alright ladies and gents. I saw a prime example today.
30A598AA-E8FF-4DF1-87A7-4DDCD10639A0-214
Notice the chain on front. If you don't have one you're a girl. Center caps are for babies. None of that on this specimen.
39CF048A-35B7-437C-A559-2CA07314CC85-214
Alright this is where the truck really comes together. Twin stacks=twice the power. Judging by diameter he's probably up about 150 hp from stock. Notice the super sized toolbox, which barely clears the ghost trailer he needs that 5th wheel gate for. Don't forget, aero is important and a gate like that clears up 5 mpg! Note the bike, very important addition here.
It's got awful euro tails straight out of 1998: +300 points.
No truck nuts: -5000 points.
:lol:
I noticed only 1 out of 4 mudflaps was still hanging on for dear life. Other than the stacks this is a pretty typical Cummins. Most of them are lucky to even have a tailpipe, they get run hard and put up wet around here. You can see a lift spacer on this one, with stock length arms(also pretty typical).
hillbilly deluxe.... i can hear the banjos from here
Stack
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
  • 10 months later...
To each their own not going to hate in someone else's truck at least they are modding it not just buying the customized one at the dealer and calling it done
Is that a freaking jet on that bug.
yes..
bottom pic you can see the turbo fan, under the back window. air intake is thru the sun roof. last i herd it was still registered for street, but CA. DMV was giving him s**t about passing smog.. :lol: even tho it still has the stock motor up front..
yes..
that would be funny as shit atthe smog place with a sniffer onthe after burner. It would toast it and blow it off before it coild get a reading.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
