Rough Country 3.5 inch suspension lift. Tires are 305/70r17 BF Goodrich Mud-terrains. Wheels are Dick Cepek 17x9 with -12 offset. Minimal rubbing under full lock.
Just got a question for all you lifted guys do you still have the problems that are described in the "Shake or vibration" thread in the problem section?
My Trail Grapplers hum like hell and vibrate the wheel around 40-50mph and sometimes while braking after i did the Zone 6.5" kit. It isn't as bad when the tires are cold and the psi is down. When they heat up on a hot day the issue kicks in. I am going to have them check my alignment again, but I already decided to move to the Open County ATs and have them on order.
That's weird youre having those issues with the trail grapplers because mine hum very little out of all the mud tires I've owed and no vibration what so ever and ride just like my stock tires did except at coming to a stop and going from a dead stop you can feel the knobs in the tires
It's got to be the alignment then unless there is something not right with the lift install. I didn't experience anything with them before the lift other than what you mentioned.
Ya nitto terra grapplers 950, 9000 miles on them.
Wish they made a 4" kit for the 2 wheel drives!
CST Suspension FTW. They have a 3.5-5" kit for the 14's
LOL @ $1,200 for a 4" lift with no shocks. For that kind of money, there's a shop here locally that will do a 6" lift WITH shocks for $1,299 INSTALLED. Or if one wanted to go with a less expensive alternative, just do a 2.5" level and a 1.5" body lift like I did and total cost is around $250.
They are high but not extreme. I paid more for a Camburg 2.5" level kit on my 2013. Also you don't need shocks with that kit since it relocates the hub; the other suspension components stay the same. It all depends on what you want, if you aren't looking for performance you can do the same with a level and body lift for 350$. He was mentioning BDS, this is cheaper than BDS. You buy the coilovers then you can get the 5" and have the best of both wprlds. You get what you pay for. Edited by CAtaylor
I was referring to rear shocks which the CTS kit does not include.
Yep, I completely jumped over that. You are correct on that one.
    Greg3160
    Greg3160
  • Who's Online   2 Members, 0 Anonymous, 485 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
