That looks awesome man! Do you have more pics? What kinda wheels are you running?
Thanks man. The wheels are the 20x9 XD Badlands (5.75 back space) with 295/55r20 Trail Grapplers. I had them on my old Silverado with a level kit for about 6 months and then traded for this new one. Had the dealer put my wheels on the 2014 and looked killer. Now with the new lift the tires are too small. I'm kind of tired of the m/ts too like one mentioned earlier. Going to move to the 295/65r20 Toyo OC AT II tires soon and a 4.56 gear. The bank account is dropping fast.
Edited by badchevy
Just got a question for all you lifted guys do you still have the problems that are described in the "Shake or vibration" thread in the problem section?
I have not a single hiccup with my steering or suspension. Tracks straight down the road.. No weird noises or vibration at any speed or over any bumps... Hit or miss if I had to guess.. I've read some info in that thread as well.. I'[m 99% back to stock ride even when lifted 8".... Come take it for a test drive haha
No problems here...mine drives better now than when it was stock.
After proper alignment..... Rides better than stock.. 15 hd 5"zone lift 20x10 bmf novakane on 35x12.50 toyo Mt
I recently ordered a Performance Accessories body lift kit with their leveling kit to add a total of 5 inches of height. I also ordered some rigid industries LED Fogs with adapter bracket so I'll be uploading some pictures soon.
What lift do you have?
Does anyone have 295/60/20 tires on stock rims with any rubbing issues with just a leveling kit?
I also have a Black Bear 91+ octane tune, 4.10 gears, cold air intake, and exhaust. 35-60mph its 17-20mpg. 60-80mph its 13-15mpg.
Where'd you get the 4.10 gears from? And how much? I'm thinking of doing a a set up like yours and will also want the larger gears. I currently have the 3.42s but heard changing to the 4.10s will save some mileage
Brett did his the same place I did and bought the parts through East Coast Gear. Going to cost you around $2300 for a 4x4. If you can wait for someone to come out with gears for the 14 it will be less because you won't need the extra parts; new locker, u-joint conversion and spacer for the diff cover. Just find a good shop, I have another set waiting to go in mine because the shop I used hosed up 3 sets now. Brett's went great though using the same shop, I personally think they just got lucky on his.
In reference to suspension lifts: Is anyone running aftermarket leafs in the back? If so which ones? I get some pretty bad axle wrap with the 5" blocks and add-a-leaf that is in mine now; It don't like the torque from the 4:56 gears. I need to keep it around 5" lift over stock so a 6"-6.5" leaf pack is what I am looking for.
Got any idea on when 4.10 gears may come out for our 14s?
No I don't. Yukon was working on them from a post a good while back but I have not seen anything on them.
I had 295 60 20 on stock rims with the 2.5 level kit it did ru. On the inner wheel well I now have 7" lift with 35s
I still have my tires for sale
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,347 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
