Idk my offset but here are my wheels, right now I'm running 305-55-20 I think, I'm not able to look since I'm out of state working lol.
d68b96970db384216caabd4255b76894.jpg4a9a4f2eca89db71db343ba099464fae.jpga06da5fd134918d0c7d4bee9bce9f852.jpg
I have a 2014 GMC Sierra all terrain with 5inch rcx lift kit , 20x10 rockstar rims with -24 offset and 305/55/20 copper zeon ltz tires , amp power step , bushwaker pocket style fended flares , boral exhaust with metal mulisha 4 inch tip ... Looking to put 1.25 rough country or 1.5 zone body lift to fit 35's
  • Like 5
Does anyone think a 35" tire on the stock rim ( Not sure of the backspacing) would fit on a 4 inch lift?
I have a 2wd if that makes a difference.
Thanks
Evan
So what made you change rear bumper to one without steps?
My Current Setup,2014 Silverado 2LT Z71,RCX 2.5 Level Kit,NittoTerra 33x12.50R20Lt's,Fuel - Octane D509 20x9 -12 Offset,All Chrome Plasti-Diped
My Up Coming Mod's,McGhauphy's 7"-9" Economy Lift Kit,Federal Couragia M/T's 35x12.50R20Lt's,OEM Tow Mirror's,Bushwaker OE Fender Flairs,Gtr Lighting Led Conversion Kit's 2,200 Lumen(High,Low,Fog),Black Spyder Venom Bull Bar,Iron Cross HD Step's.
Thanks
Evan
Yes you can fit a 35" tire on a stock rim with the Zone Offroad lift or the BDS kit. I have seen both done and both are in this thread. The BDS lift is the 4" lift with stock 20" AT rims and a 275/65/20 BFG AT. The Zone offroad truck, 4.5" lift, has the stock chrome 20s and Cooper ST Maxx 35x12.5x20 tires.
I believe the member's names are Pancepance (BDS) and Mcrunner (Zone)
both of their trucks were 4wd I believe.
Hope this helps
I've also seen a guy running the rcx 2.5 level with stock wheels running 35s, yes it rubs but not bad he said. Wasn't on here tho was on Facebook.
Edited by 2014Sandylifted
Mine came like that apparently from factory , it was the last all terrain on the lot so they gave me a good deal on it
Can someone with the Zone 4.5" post a picture of their angles?
I have a crazy idea which I dont know will work or not. I'd love to lift the front of my truck about 3.5 or 4 inches but I don't want RC's 3.5" kit and I'm not spending the money for BDS's 4" kit (which I read is way over 4 inches anyways). I'm also not interested in overextended 4" kits like Mcgaughys or Readylift.
What if I installed Zones 4.5" kit, for example, but used RC's 3.5" spacers from their kit (or Bilstein adjustables with a 3" level block)?
Stupid idea? Would my angles be in the negative? I think Zone's 4.5" angles are pretty flat so I'm thinking the angle of my axles might be inverted.
Edited by 14x4
I will when I get my truck back this week.
how much u think about hat 4.5" zone will cost
Sent from my iPhone
using Tapatalk
Having mine installed w airbag, spacers 1900.00
Does anyone have a picture with a 3" Performance Accessory body lift on a 14/15? I already have a 2.25" Pro Comp Level Kit installed and I am thinking of getting a more economical 3" lift for the body. Thanks!
ive got bags with the rancho quicklift but I want it up higher now with little bigger tires. [emoji106]
Sent from my iPhone
using Tapatalk
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
