For anyone who was wondering about tire fitment with a 4" lift, here are a few pictures of my truck. I ended up going with a 4" Fabtech and 295/60R20 Nitto Trail Grapplers with stock wheels. Rides great and only slightly rubs the plastic wheel well and full lock. Hopes this helps anyone who was curious.
I hate you for this. I was going to go with a 6" and 35s but looking at your truck it makes me question if I really need that big of a tire.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Anyone have any popping/clunk come from the front of their truck after their lift? I've had the shop check everything and all bolts/connections/linkages related to the suspension and diff drop are all tight. Wheels as well. They recommended having the body mounts checked, since Silverados can have problems with them? They also said it could be driveline slack.
Going to have it looked at during it's oilchange coming up, but figured I would see if anyone here has any thoughts.
Had some fun ripping my truck through the mountains this past weekend. Trails were in Big Bear, CA. 71705a273c5b5af17b93779f8f983f83.jpg
You have some long travel on that bike, what type of bike? I have a 2016 trek fuel ex8 I play with on the trails down here in Texas.
Nice truck/bike!
Nice truck/bike!
Thanks man. I love the truck and bike. That's my full on downhill bike with 200 mm of suspension up front (Boxxer dual crown fork). I use it at ski resorts in the summer that are lift operated bike parks/trails: Mammoth, Park City, Big Bear etc. Bike is 2013 Specialized Status II.
Mine popped first left hand turn of the day, but not always. It doesn't do it since an alignment. The only other difference is it is much warmer outside now. I think the pop was a ball joint.
2016 Silverado 1500 Wt Midnight Edition
Camburg 2.5 Coilover Kit
285/70R17 BFG KO2 on Method "The Standard"
20160704_155641.jpg 20160704_165341.jpg 20160704_165537.jpg 20160702_182604.jpg
Sent from my SM-G930P using Tapatalk
How is the ride with this set up? I am looking at purchasing this kit so I can clear 33/12.50/22 with a +12 offset. Looking for improved ride over the stock set up...so hard to figure out if it's worth the $2500 or just get a set of blistering 5100's for $350. Any input you have would be greatly appreciated.
The ride is perfect. I spent a lot of time looking for the perfect kit to level the truck and improve on and off road performance. I got exactly what I was looking for.
The ride on road is the same if not a little better than stock and off road it is night and day. The coilovers really absorb large dips on road and rough dirt roads off road.
Also the guys at Camburg are easy to work with and would answer any questions you have. I would call them because they have recommended wheel off set for this kit and right now i dont remember what it was.
Anyone having issues in 4wd after lift? I have zone 6.5 in my 2016 Sierra and when turning in 4wd I hear clicking noises and it feels like it's binding up quite bad, but going straight it feels ok. I just noticed this and lifts been on since February but I haven't really used 4wd
Sent from my E6853 using Tapatalk
I've used my 4WD a few times on dirt and sand since lift 2 months ago and it seems to function the same way as before. I'll take another look at it when I leave work but I believe mine is the same as before. There is a notable difference in feel, turning, handling, ride comfort in 4WD even when these trucks are stock. Did you use the 4WD prior to lift?
On turning it will make a noise in 4x4 because it's your differential working.
I think it was because I was on hard dirt, getting to much grip kinda like what would happen on pavement. Lesson learned lol
Fabtech 6 inch with no issues.
Please help me...
I had a 7.5rcx lift put on my new 2016 Sierra last weekend with 35's. Now my stabilitytrac and traction control lights turn on when making turns at slow speeds. The CPU must think my truck is about to flip over when turning now. Anyone with this issue before? I need help!
Here's another issue I've noticed also... Now I'm getting a bad vibrating at 65mph and up after the lift, was fine before. I'm really starting to regret this whole lift thing. :(
Please help me...
Should regret that particular lift
    Chris80s
    Chris80s
  • Who's Online   4 Members, 0 Anonymous, 834 Guests (See full list)
    • Still $3.01 with even more places at this price
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
