If you get a chance to get a photo from the side just to see how much the tires stick out, i'd appreciate it! I really want to get the Zone 4.5'' lift with 35's but I don't want to have a rub that I can't fix/trim. Also, you guys suggest the RT's over the MTs? Just noise level? Or ride comfort as well? Thanks!
Best side-ish shot I have on my phone. Zone 4.5" with 305/55s on 20x10s
I'll get a dead on side shot this afternoon
Thanks Wildchevy, your truck looks awesome man. Ill be going with 20x9 with 20mm offset so i dont think mine would be stucking out much. Just need someone to tell me to buy the 35s and risk an easy trim job.
thanks!
I've got the Zone 4.5 and its done very well. no problems out of it. I dont have any pics of the angles right now though. i'll try to get ya some
Looking to do the same. 14 Sierra SLT 2wd with stock 20 wheels. What tire size are you running and how do you like the kit? Thanks
Edited by Beefjr
Got a few shots for ya...
Very dirty but it's too chilly to wash right now
Remember i have 1.5" spacers in the rear and nothing up front...
All is just ur standard 4" BDS lift with the 35x12.5x20 toyo RTs
5b5dea4022422de5e2ca304e9f47e95f.jpg0483b4b74f2702f5d030dc94ed71aa2a.jpge14893b2fc29163c0345eda35495eaa5.jpg
Sent from my SM-G935V using Tapatalk
With the Fox coilovers my truck definitely rode better than stock.
Well yeah I know yours does man lol. So does mine with fox coil overs. But the dudes with a 7" rough country, for example, are smoking something haha
Probably crack or bath salts, possibly a combination of both lol.
Did you have to do any trimming for the 35s to fit?
Sent from my Pixel XL using Tapatalk
Not one bit of trimming was done. If anything it just rubs the liner a tad in reverse at full lock. It looks wayyy close but everything fits just right.
Very nice. It's a similar setup that I want to get. I want the 4 inch BDS lift. How far out do the tires stick? I read because of the knuckle on the BDS lift that the front is out further than the rears. So I assume they stick out a bit and you need to get fender flares. But from the picks it looks like you don't need that. Maybe if I don't go for as wide as a tire, they will tuck in just nicely.
The tires stick out about an inch from the fenders. The fronts get pushed out because of the kit and the rears stay tucked inside. I have OCD so i had to space out the rears with a 1.5" spacer to even out the look or i would have gone crazy looking at the difference.
Sticking out is all personal preference but i very much like it when the tires stick out just a little.
Agreed. I think the tires sticking out a little looks great. If I go with the RCX 5" I'll need spacers for the rear as well.
I was running 295/60/20s and still rubbed at full lock with some trimming.The kit itself was a good kit and could complain. i did have coilovers custom built for the kit so that helped out on the ride. I just traded my truck last week lol.
Fabtech 4" lift, 295/60/20 trail grapplers on 20" BMF REPR's
Looks great!! How's the ride any issues with the lift after some time?
Thanks
    • I am new to this… but I saw some of your replies to another person doing the same as me… trying to replace the temp control actuator in my 05 GMC SIERRA, And can NOT get to it… how do I get the center console panels off, do I have to take ALL of them off to get to it? 80481681120__F97CE005-C5E5-4FBF-9589-1388214E3586.MOV
    • I will be one of those "blinded". One, I like new shiny things. Two, I've never kept any of them beyond the 3/36. Three, I don't finance anything. Four, yep, it's a waste of money....so,what? I'm doing my part of keeping automotive industry going and keeping my neighbors, most of whom are in it, employed. 😉      By the way this is the "signature... ¬
    • Although there is a "recommended" weight by those who sell trailers, my experience has been that they are way too aggressive in their information, for me at least. My '22 with 6.6 Gas, has a payload of about 3400 lbs and depending on your specs (I don't have 4WD so it has a bit higher Payload than others) yours will likely be different. Payload is one of the most important numbers for towing. Although you "could" tow the max trailer weight for your truck, I, personally, would not go close to that number. Having said that, a lot depends on how/where you will be towing. I live in the LMD of BC and often tow to Denver, Co, along interstates (flat and mountains) and I find I need to keep it in 5th (6spd) for the trip and travel at around 65mph. This is for a trailer dry weight of just under 3500lbs. If you are only doing local, short trips, it would not be that big an issue if you had a heavier unit. You will be surprised how much stuff you load the trailer with, so I would only recognize the trailers "full" GVWR weight rating, then decide on the appropriate trailer from that number. If you are worrying about how much stuff you should be putting in a trailer, you might have too large a rig from the get-go. Once again, depending on what terrain/distance in which you will be pulling. Marv
    • davester, Thanks for the response, how ever, I think I am now a bit more confused than I was before I posted - - After I posted, I actually found a YT video of a guy who replaced his Module (above tire) and he only disconnected the ground cable of the battery, but you describe rubbing the two cables together after disconnecting. I presume that is to do as you describe and eliminate any residual energy? - When I picked up the Module (between my posting and reading your response) from the dealer, I specifically asked about any re-programming and he stated it was not necessary as it was simply plug and play. Don't know how knowledgeable he is, though. - The video I watched also showed the Module plug to be difficult to "unlock" and remove, but there was no mention of silicone, although the video did show a bunch of dust/dirt in and around the plug (old truck) during removal. Are you talking about silicone that was applied by the factory, or silicone that you applied prior to plugging in? Thanks again, Marv
    • Looking for a clean, factory-style lighting upgrade for your 2022+ GMC Hummer EV? M&R Automotive's 40" Bumper Light Bar PRO features a vehicle-specific, bolt-on design with no drilling or cutting required. Choose a bright white or yellow main beam, both paired with an amber DRL backlight for a sleek OEM-inspired look. The kit includes a curved LED light bar, powder-coated brackets, and all necessary mounting hardware.    Learn more or order yours See how it installs and looks on the vehicle:
