Is it your wheels hitting the front fender? If so check out the NorCal Mod. If you don't want to do the Mod just don't turn your wheels all the way. I have 2017 Silverado with a 6" Fabtech Lift, Fuel Assault 20x10 -18 offset, 35" Toyo Open Country R/T......minimal rubbing only when backing up and turning sharp.
no rubbing nor did i have to do any trimming i have not heard of the nor cal mod ill have to do some research my rims are +18 so i got away without cutting.
Is the clunking occurring when you hit a bump or when you turn? Just curious.
yes to both:( once i get up to speed above 15 its fine even when turning its backing up or turning at like 5mph that it clunks and its quite loud
Mine rubs right on the back of the front fender. I bet yours is rubbing also. I would check under the fender well and see if you can find any marks. Also crank you wheel all the way left or right to see if it touches. It may not touch but if it is close it will probably rub while in motion.
That sucks guys. Hopefully its nothing major.
Hurry up and figure this out before I add my lift and tires. Haha
there are A LOT of discussions on this topic but yet to find one person to specifically point out what the problem is its not like a hey if you are having that clunking/popping noise yo need to do this to fix it. it usually ends in has anyone figured out a way to fix this lol
I'm assumingit started after you added the lift.
Nice to know. Never lifted a truck before so this is New territory for me. Always had lowered trucks. Never had any issues if done correctly. A lot less components too.
Is anybody here a facking Procomp genius or what? I can't, nor can the procomp customer support find the correct part number for the 6" lift for my truck... All I want is their best kit, front coilover, best rear shocks for my 2016 sierra 1500 cast control arms build date of 03/16....... heeeellllllllllllpp
Got a new to me '14 High Country.
Thinking I'm going to go with the 4" BDS and the rear leaf springs
Probably pass on the coil-overs due to the cost.
Anybody willing to provide an invoice showing less than MSRP? (on 4" or 6" BDS),
I dropped by my local authorized dealer and they quoted me the same price as what's
on the website, obviously I'm looking to save a few bucks...greatly appreciated.
Btw looking to use the local dealer here in Colo. Springs (Predator 4x4), however if someone
has had success with a shop in Denver please fire that out there might be worth the drive.
Edited by oodmoff
Well got all the parts ordered yesterday just waiting for shop to call so I can drop truck off, got 6 inch bds with 35x12.50r18 toyo rt on fuel assault 18x9
I've ordered my lift and rear leaf springs through the dealer and the price is the same pretty much through them and from the website. Only real difference is you save on the shipping by gettting free shipping sent to the shop
b5e51bacd616fe2be28adeb43408fe84.jpggot my fox coilovers installed the other. Drove from California to Utah. The truck drove awesome
What lift you got?
    • You need a better code reader/scanner.  You are missing codes.  Did the dealer give you a copy of the SAVI scan from that visit?     If the fluid hasn't been changed, change it.  Shudder will likely go away.
    • TLDR to my other post...   Hard. Pass.  Too many what ifs.     Are you set on a 3.0 Duramax?  Have you considered anything not GM just in case?  If you don't have to have a pickup, lots of other options for $27,000 out there.
    • I see some red flags.   - No mention in the Carfax if the oil pump belt was changed.  LM2s had a 150,000mi service interval, and its got 164,245mi on it.  So right out the gate it needs about $3000-3500 for that to be done before driving it another 150,000mi.  Belt is at the rear of the engine.     - If something happens to the transmission valve body, the special coverage is expired by mileage.  That will likely be an out of pocket expense, with zero or near zero GM participation if something happened even though its in by time.   - 2020 LM2s seem to need timing chains after 80,000mi at some point.  They fixed this end of 2020/starting 2021 model year engines.  They will usually set a P0016 I think?  There is another $8000-10,000 if it needs a chain.  The main chain is at the back, secondary at the front so the pump belt would be done at the same time if it needed chains.     - Long oil change intervals.  7,000-8,000mi on average, probably close to 0% or perhaps to or beyond 0% on the OLM.  Lots of them not at the dealer which makes me wonder how much of the oil ran through that truck was the proper Dexos D rated 0w20 oil and not just gas engine 0w20, which is not the same at all.     - Long fuel filter changes, again likely taking the fuel filter life to 0% or more.  First one went 28,603, second was done 43,094 miles later at 71,697, from there another 46,452mi to 118,149mi, and then the most recent one 37,026mi later at 155,175mi.  So counting its original fuel filter, its had only 4 fuel filters on it.  No bueno IMO.         Good news?    - It has had only two warranty trips to the dealer.  The first free service (end of December 2020 on the Carfax), and the transmission reprogram recall (end of August 2025 on the Carfax).     - Truck did a LOT of moving, so that might explain the lack of emissions related repairs like bad NOX sensors, bad exhaust temp sensors, bad glow plugs, etc.         The "emissions system checked" could just be how something was flagged for Carfax.  GM dealers have to do SAVI reports for warranty repair orders so they scan the truck.  So its possible that is there for that?
    • Thank you, @Z45!   NOTE - No all repair shop/Dealers reports to Carfax   That is my main concern.  The CARFAX looks way too clean for a 6 year old anything with 164,245 miles.  Even something known for reliability (like many Toyotas) typically has a lot more replaced, like a Nav screen, interior trim, shock/strut, or brake pads.  And surely the last set of tires (installed at ~58k miles) would be bald unless those were all highway miles.   I'm tempted to pay a local dealer to look up the VIN, but am not sure if that will be worthwhile.  Last time I did this, it was 100% useless, and I felt scammed - they noted the bumper was replaced years ago and that's it.  A 5-year old could spot the accident damage, even though nothing was on the CARFAX.   After giving the dealer a call, the truck may have a hard shift, but they have to verify with their mechanic if that's even a concern.  And I've test driven about a dozen of these now, many near Chicago, and half the trucks shift hard/odd at all throttle positions.  The ones with aftermarket lifts/larger tires shift terrible, and 3 stock trucks shifted so violently I thought the transmission valve body was going out.   At this point I'm conflicted, as I need a vehicle, and am coming up short locally.  Northern trucks in this price range tend to have either multiple owners, a lot of mods (lifts/oversized tires without re-gearing), and are generally in rougher shape.   If this truck showed up in your neighborhood for $27k and you had to purchase it sight-unseen, with the possibility of needing a 10L80 rebuild, torque converter, or rear end - would you do it?  I'm convinced most of the 10L80 trucks I test drove are broken, they can't all shift so bad, with massive flares/slipping/lurching and mis-matched downshifts like a teen driver learning stick.
    • From the spy shots, the front end does look like it's borrowing some styling cues from the Canyon. I'm more interested in the powertrain news than the screens though. If the 3.0 diesel survives into the next generation, that alone will keep a lot of current owners interested.
