you can run stock 20/22s on both kits as long as you don’t have stamped steel control arms.
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone
22x10 AF Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
Stamped steel rub ? My 17' Denali came with stamped :(
yup, stamped steel are the difficult ones. I couldn’t run stockers because of them.
4.5" Zone
22x10 AF Grips
And to clarify, I have stamped steel control arms. No rubbing and the only "trimming" needed was to remove the front valance. It could have been trimmed some, but removing looked better imo
the inside of the tire isn’t rubbing the UCA?
4.5" Zone
22x10 AF Grips
the inside of the tire isnt rubbing the UCA?
4.5" Zone
22x10 AF Grips
No it's not. Even at full lock, it still has about a 1/4" clearance
thats so damn odd lol.
4.5" Zone
22x10 AF Grips
This is 6.5 Zone with add a leaf in rear with Method MR306s and 35x12.5x17s
Excellent stance IMO I love the perfect level86a64a62e9eff946f9d6b5d3a9d0a456.png
What is the tallest lift you can get online that you can do yourself? Is the 6"/ 7" the tallest?
Picked up a 2017 1500 4wd LT Z71 this weekend.. and want to get a lift as soon as i can..
Im sure id be good with the 6", but if i could go taller for not much more, id rather do that.
FTS 10-12” or Cognito 10-12”
4.5" Zone
22x10 AF Grips
So dumb question, going up to the 10 or 12, or even the 6" seems that most kits come with new shocks and such.. Since i just got the Z71, how much of that package would be replaced?
z71 is just color matching, badging, a skid plate, G80, shocks, fog lights.
4.5" Zone
22x10 AF Grips
ok, so not really loosing anything but the shocks with the one that come in the kits..
yup. Those kits are NOT cheap, especially Cognito
4.5" Zone
22x10 AF Grips
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
    • Yes, you must have seen my thread on the Blazer. HOT GARBAGE, but I love them anyway. I'm convinced every car guy has a soft sport for an S/T series somewheres. Probably even a Panther too, if I'm being an honest car guy. That doesn't mean they aren't junk. And they definitely don't get better with age. I sometimes play with old cars, but that's by choice. I don't rely on them and they aren't my everyday fleet.   Derek plays the common man on Youtube and that's no doubt where he started. Now he has Youtube money (and Motortrend, etc). You think his crews and his wife ride around in old beaters when they're chasing him and his wrecks across the country? No he's got newer and nicer stuff for that, you'll see glimpses of it in the footage.
