2 hours ago, Bigrich said:
Why not go with the 6 inch? I hear guys say I wish I would have gone higher. Same price for 6 inch from Fabtech
I won't speak for @jimmyboy8301, but for me I just want something with a little higher stance than my stock truck has now. I'd probably be happy with a leveling kit, but would much rather got a tab bit higher with a 4" and get a nice suspension lift knowing that the drivetrain and suspension is as it should be without causing a lot of stress.
The nicer kits don’t put any stress on the steering nor suspension. My 2015 Denali with 6 inch Fabtech stills rides like a Denali. Just giving my experience with a 6 inch lift to ease the minds of others considering lifting there truck. Not trying to but in.
Sorry, I wasn't referring to the bigger 6" lifts when I said adding stress but more of the leveling kits. In nearly every case I've read leveling kits just push things causing sharper angles, stress and so on - or at the very least makes the truck drive a bit stiffer.
Your absolutly righ about that! My truck rides better with the 6 inch lift then it did with the 2.5 level kit. The level kit caused one of my magnaride coil overs to leak. Buying 2 of those took away some of my tire money. Lifts are better than levels!
Personal preference. Zone and BDS are the same way
2017 Chevy Silverado LTZ Z71 6.2L
4.5" Zone w/ Bilstein and Fox
22x10 American Force Grips
33x12.5 Nitto Ridge Grapplers
Instagram @wildchevys
I guess it depends on how much of a spacer you go with also. On my 2WD I went with a 2" spacer after doing a 5" knuckle. I felt more of a difference in ride after switch wheels and tires then just adding the spacer
Are you guys installing these lift kits your self or having a shop do it for you? Me personally I’m going to do it my self. I’m trying to save money on the install and save some more with the RC 7inch lift. With all this money I saved I can get the Fox shocks front and back. Yes I understand people have there opinions on lift kits and people like bds or zone better then RC but it has been used so many times and people have loved it. That is my opinion on lift kits and why I will choice RC.
No one mentioned Fabtech? I’m very satisfied with there 6 inch Gen 2 kit. Track width stays the same. Angles great! Sits level! Rides great & no lights on the dash. Affordable also
BDS and Zone are two favorites and hard to beat. However Zone doesn’t offer a magnaride kit
SuperLift 8” Suspension lift going on this weekend with their King Coilovers and King rears [emoji51]?
@westernsilverado on Instagram to follow along!
6”skyjacker lift kit it’s been on for a while...  but I was wanting more lately so I added rancho level it struts 70k so I figured it was time to replace anyways...   I pulled out the 1” lower strut lift I had on there so the extra inch is barely noticeable but rides fine.  Adding new UCA’s next weekend before I get a new alignment.
rear has 5.5” blocks rear add a leaf and lift shackles.
On 5/29/2018 at 10:19 AM, Willie will said:
So I got bored at work and most garages are 7ft tall. Stock overall height of a Silverado is 73.97 inch’s. Also add a 7 inch lift. 82.97. Stock tires are 265/65 which is about 30 inch’s. I want to upgrade to a 35 inch tire. So overall it’s 87.97 inch. Which is approx 7ft 4inchs. So I don’t know if I did that right lol but looks like I won’t be able to park in the garage. UNLESS I get some bags hahah.
I'm pretty sleep deprived but I think you did miss the math a little. 73.97" + 7" would make 80.97", not 82.97". Then with the tires, you are adding 5" of diameter, but only half of that is pushing the truck up, the other half is going up into your wheel wells. So by my math, your overall height would be 73.97" + 7" lift + 2.5" tire size increase for a total of 83.47". By that, it'll be dang close! I think I saw someone on youtube with a 6" lift and 35's fit in a 7' garage, so you might have a chance.
well see. hopefully its a perfect fit. if anything I heard people modifying there garage a little with replacing the board on the top of the garage door. my math is horrible lol
On ‎4‎/‎27‎/‎2018 at 11:20 AM, jballs15157 said:
Thanks for the compliments, it came out exactly how I wanted it.
I did have to use spacers with the stock wheels to avoid the lower control arms.
BORA 1 1/4" up front and BORA 1 1/2" in back to keep everything pretty even.
I do rub a little at full lock on uneven surfaces but nothing to be worried about.
What type of lower control arms did you have?
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
    • 2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck  I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one    #1   Since we have owned our truck purchased new it has this strange noise after using the remote start function  you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .   There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of     #2  You can only hear this if you are standing outside of the truck and near the truck  you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally    #3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again  I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it . Now its back in the Dealership left it overnight so they could possibly hear the problem . They said they tried and nothing happened . Well they did not know what they were listening for . I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership    Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like  Really  would like to know if this is anormal sound  Thank You Fellas !!
