18 minutes ago, 14 Silvy said:
Where’s the best dea on the CST 4.5 stage one kit ? I just bought a 2018 Silverado and think I wanna go that route due to not increasing track width.
I bought mine from Performance Lifts. mainly because I bought my last lift there for my 2013 and they have great customer support. New Level motorsports has it a little cheaper then Performance, I think they are around $1650. for the stage 1 kit.
Cant wait to see it. Strongly considering this lift and squeezing some 35s. Love that it doesn't increase track width
Sent from my SM-G950W using Tapatalk
I’ll post a bunch of pics once it’s all cleaned up and can compare the before shot
To the new shot....
Pic coming soon [emoji13]
I’m also looking at keeping the same Nitto Ridge Grapplers 285/60/20’s (33.7’s) but may go up to the 285/65/20’s cause I want to have less drag from the tires width wise but a bit more height for a softer ride, I don’t know [emoji1745]‍[emoji3603]
Sent from above
30 minutes ago, chrispassas21 said:
I have the fox 2.0’s not exactly sure what they are set too. Don’t think they are the same as bilstein to adjust like that. Sorry about that
2015 Silverado LT Midnight Edition
4.5” CST suspension lift
The Fox 2.0's adjust with a spanner wrench, mine are at 2" because I was just leveling my truck when I installed them. Yours most likely are at "0" otherwise you would have gained an extra two inches of height over the 4 1/2" CST spacer.
To the new shot....
I’m also looking at keeping the same Nitto Ridge Grapplers 285/60/20’s (33.7’s) but may go up to the 285/65/20’s cause I want to have less drag from the tires width wise but a bit more height for a softer ride, I don’t know emoji1745.pngemoji3603.png
Sent from above
Looking forward to the pics!
One thing is for certain, (and I know lifts, had many of them) it seems to be a much heavier duty and very thick steel, highest quality paint job I’ve ever seen from any manufacturers suspension components. Very impressed!
Sent from above
That’s not including rear shocks for the 3”-5” lifted applications.
Sent from above
2016 Silverado Z71 Crew Cab. 6” Pro Comp lift kit. King Coilovers in front. King shocks in rear. 20” Pro Comp wheels w 35x12.5 tires. Borla Atak dual side exit exhaust. 51882a33086725c9597b8a444bf9a8d5.jpg8b57b99c93083b64bbf552d865aa9093.jpg8a66fca1e191d9eadb88ad9eedf43462.jpg
Damn i love a nice set of kings they look bad ass. Nice truck man
Ok, how’s the ride quality of your Kings, stiffer, mushy?
Sent from above
Sent from above
Best money I ever spent on a suspension. Feels like a Cadillac. Both front and rear are adjustable so I can make it stiff or mushy. I’m set in the middle with no complaints.
I’ve heard great things about King suspension. First I was looking Fox, then did the CST lift so naturally just about jumped on those but I’ve heard such great things about King suspension and now you, lol. I’m interested to know which stock# for the 4.5” lift would work as well as the rear which currently running 3” blocks, looking at going 4” just cause it’s perfectly level but I like a slight rake up front. Do you know your model #’s?
Sent from above
Just decided to go with CST full adjustable coil overs. Their amazing quality is out of this world but 100% made in The USA [emoji6]and will only compliment my awesome CST lift [emoji631] Thanks for the input!
Sent from above
On ‎11‎/‎15‎/‎2018 at 2:31 PM, TXGREEK said:
Just decided to go with CST full adjustable coil overs. Their amazing quality is out of this world but 100% made in The USA emoji6.pngand will only compliment my awesome CST lift emoji631.png Thanks for the input!
Sent from above
Just wanted to ask if you have the lane keep option on your Sierra?  Came on my LTZ with the forward collision alert. Just wondered if  any problems with the lane keep after installing the CST kit.
Edited by SSchup
correction
Great question, No issues at all. Well, maybe, constant desire to do more upgrades lol. In all seriousness, absolutely ZERO problems, as far as mods on my truck, best decision I made was the CST lift.
In the constant desire to do more, these just arrived
Front
Rear
Awesome craftsmanship, second to none
If you do end up doing the CST lift, get the Stage 1, this way you can do whatever shocks and struts you want and when and if you want to add CST coilovers like me, you’ll have the CST upper coilover, strut and spacer assembly as backup or spares.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
