I've been able to get 23 ~ 24 mpg registering on my DIC active mpg recorder in 25 mile increments (don't know the real name of this screen). And, 20 mpg while on road trips running 70 ~ 75 mph when calculated after going through a full tank. This is far better performance than my 2008 Silverado 5.3/4 spd CC delivered. I'm thinking the excellent mileage is a result of the 6.2's great hp and torque which enables the engine to spend more time in 4cyl mode and tranny to spend more time in 7th or 8th gear. Btw, seeing excellent mpg results when towing my 25' 6,100lb TT.
7 miles into town and I live on a really steep hill and get 16 mpg. Only 2 mpg less than my taco 4x4
My best 25 is 39mpg
Forgive me, but I'm old and not current on new lingo; what's a "taco"? A Tahoe maybe?
Tacoma
An experiment I did. 60 mph cruise control set on my commute. 90% highway. 563 miles to the tank. Best 25 mile mpg was 30.6. Filled up the tank with 24.5 gallons.
Edited by 16z71Tom
On a recent round trip from Clearwater, FL to Sarasota, FL, I averaged 23.2 mpg. This is outstanding mileage. I tend to tap the brakes when I see the stop light is red to let the truck coast (not excessively) a bit before I brake to slow. Around town, my commute mpg is 18-20 mpg (with some stop-and-go). I hope to achieve better mileage on a longer trip with max speeds 70-75mph.
2014 Silverado High Country, crew cab, 5.3L. Only mod is a K&N filter in the stock air box.
This is the kind of performance I hope to approach on a long trip. With Cruise and some coasting downhill and approaching stop lights. The truck seems to know when it should be in v4 and v8 mode.
I turned off brake assist and i think my mpg went up a little
Sent from my SM-G900P using Tapatalk
how do you turn off brake assist?
Now that I've done the 6" lift, 35" tires and taken the front air valance off, I'm seeing about 16 MPG on the same stretch of highway where I'd previously get 24 MPG (that's adjusting calculation for new tires). My all around driving has been more like 3 mpg drop off. City isn't nearly as dramatic a drop as freeway when I get all that wind resistance. What's interesting is I clocked about 15 MPG on a stretch of freeway that is 19 MPG without lift and tires. It seems the air resistance allows for about a 15/16 MPG highway max at 65 MPH regardless of whether I'm going flat or on a decline. All that wind resistance seems to counter act going downhill! Anyways, just thought I'd post it in case someone comes looking for MPG before and after a 6" lift and 35s.
I personally don't mind the drop off. I knew it would happen and I didn't buy a truck or lift one to save money at the pump; however, it is interesting to watch the performance. It is also noteworthy that my 2009 Suburban LTZ with the 5.3L, and no changes to stock setup, got the same mileage as my lifted truck does now. The engine enhancements and difference in weight accounts for this.
Hold down tow button 5 sec
do you have to do this every time you start the truck
  • 3 weeks later...
This was today and at that point I had put those 15k miles on it since I got it.
Edited by Eddie 70
    whenindoubtuseahammer
  • Who's Online   0 Members, 0 Anonymous, 289 Guests (See full list)
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
