This was taken last week when I filled up. So far I have put this many miles on the truck. Hopefully it stays like this. We will see.
Holy crap, nice job.
Sent from Tapatalk App - Samsung S6
Very nice. What are the specs on your truck?
I did a 5 hour drive yesterday with the majority of the driving on 75mph highways/interstate and rolled up to my house at a 18.5mpg average. That's a lot better than with my old 285/65/18s.
Haven't hand calculated it but It will only go up from there with a hand calculation.
Running 275/70/18 BFG KO2s and a 2" level.
My best at 60 miles one way to work is 24.9MPG on the 31 mile avg. Mostly at 60MPH. Take off has a lot to do with mileage conservation as well. with only 800 miles on the truck, i haven't planted it yet.
It's still stock. 14 Double Cab with 5.3 2wd. No lift.
I stopped paying attention. Much better than my 2005. This truck excels on the highway on cruise control. City is another story, especially the way I drive and with my duals.......
My 2014 Sierra 1500 crew cab with a 5.3 liter has had horrible fuel mileage since I first received it on and took ownership of it I've been hovering around 13 and a half miles per gallon. Doesn't matter if I'm highway or city if its city it's a little bit worse and those are my manual calculations. I have very sluggish acceleration my transmission is all over the place doesn't know what gear to pick right now it's at the dealership to try to fix it all and I have a 2015 Silverado with the same engine and configuration and I have no throttle delay I have all the power there unlike my truck
This trip was all highway
That is how mine looks right now too. Last two trips to Atlanta from Tuscaloosa I have averaged 13.4mpg. Before the winter blend of gas I was getting about 15.5-16.5mpg. But this is also with the 6.2L, 6" lift, 35's and 3.42 gears. Once gears are released later this year this should hopefully jump up.
Sent from my SM-G900P using Tapatalk
Averaged 19.7 mpg hand calculated on the drive from Ft. Lauderdale to Greenville, Alabama. A little lower on the drive back. I can't complain, since cruise was at 70-75ish all the way.
DIC indicated around 21 mpg.
  • 3 weeks later...
My 2015 LTZ CC 4x4 6.2L gets better mileage than my previous 2008 LS CC 5.3L in all aspects; town, hyway, towing, you name it. As others have commented there's a big improvement when road tripping on the interstate whether towing or not towing. I'm guessing a big contributor in mpg improvement has to do with going from a 4 spd tranny to an 8 speed tranny. And, the 6.2 having enough hp and torque to lope along at interstate sped (in Texas that means somewhere between 75 ~ 80 mph, ok 85 mph, lol).
"Hi everyone! I'm new to the forum"
Uhh, new to the forum? With 1,177 posts? But, it's a good post nevertheless and getting some interesting discussion. Just wonder though why you feel it necessary to characterize yourself as new to the forum. Just curious :)
"I know a lot has been said that DIC fuel mileage systems are not accurate,but this software tends to tell a different story"
I had it on my 2005, 2008 Silverados, and now my 2015 LTZ. I've found them to be fairly accurate as long as I'm consistent in the way I cap off when filling up.
    DM22
    DM22
  • Who's Online   3 Members, 0 Anonymous, 1,554 Guests (See full list)
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • As a matter of amusement I’ll leave this conversation with this. Do you beat the government average fuel estimate? Statistics are a guide to me. Not a rule. Someone once said I have to have the last word. If true and possible may be. I’ll blame that on working in a family business.
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
