Sorry to bear the bad news, but you bought the wrong light kit. That's for the 14-15. 16+ has a different plug.
No the 23295942 is the 6 pin one for the 2016. The one for the 14-15 is a 8 pin one. So I have the right part, just having trouble finding where the plug goes.
All the way to the right? According to
https://www.gmupfitter.com/files/media/photo/735/UI%20Bulletin%20_129b.pdf
that would make it the x400 plug which is already used by the tail lights.
That would be the one, if you have something plugged in there you are already wired for cargo lights. Here's some pics from mine I just took. I did mine 2 weeks ago.
Edited by Hoytshooter
Thank you sir. I am going to go check what is connected in the X400 but it's def. not the cargo lights cause the only lights I have in the bed is the lights next to the middle break lights.
I ordered the OEM jumper harness, DT connectors and led strip lights and did a custom install given that my LT didn't come with the cargo lights. It turned out great. I used extruded aluminum channel to mount and secure the lights. Also, ran one strip across the center of the bed using my tonneau cover seam. It provides even more light in the front and the rotates up with the cover when opening from the back or front. I used a DT connector for the center strip so I can simply disconnect it to take the cover completely off.
Looks good!!
Look at all that fresh paint to scratch and scuff
I bought some truck bed LEDs from Autozone, 4 pods on each side, and hooked them up to the hitch harness. I just put a switch in the bed for now under the rail until I can wire them into the cargo lights with a constant so I can turn them on whenever. But for now they work great and the light output is awesome for having a black bedliner. I'll post pics later
Bed lights
Edited by 15BlueSilverado
I like that. I want to be able to turn mine off and on from the bed. I don't want to have to walk up to the cab and turn them off and on.
Just picked up my truck last week and want to put some lighting in the bed.
Which ones did you use from Autozone
Edited by Albytruck
I paid like $25 bucks for the set and they're awesome. I'll post pics of the switch later when I get home.
Cool!! Thanks I am heading out of town tonight. so I may not respond for a few days
I got my kit GM P/N 22933562 from a guy on Ebay for $40.00 shipped. Harness, fasteners, and lights included, all new unused parts. Interesting that the kit was not shipped in the factory box. Hmmm...
Installed it, plugged it in, and it works. What else could I ask for for $40.00 ???
Thinking about buying the other one he has on Ebay right now for the same price.........
Edited by Enough
Here's more pics of my setup. Just need to install some better clips to hold the wires. b4aedaacb6f19180e0b4f71c535c3be1.jpg0dd601177bff4fa6ef0b9dd40f7db081.jpge27c58995cdb8c1162d5f7c716765f0a.jpgfbce0a468992b56e040b2c22699f9e23.jpg
The ones I got were something like these but a different brand. They were the black pods with the angle on them so when you mount them flush, they're aimed downward which I like.
https://www.amazon.com/Alpena-77003-UtilityLite-LED/dp/B00D1SWESY/ref=sr_1_83?ie=UTF8&qid=1483621621&sr=8-83&keywords=truck+bed+lighting
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
