2014 Toppers, Caps, Campers
For those with rugs, did you seal the tail gate? Does water get inside? I assume the topper seals to the top of the bed, but I was quite surprized to see daylight through the edges of the tailgate. I really like the SUV idea of how these can be. Yukons are $20000 more then the same thing in a Sierra. I'll take a $2000 topper anyday.
  • 3 weeks later...
  • Replies 307
I have the ARE Z Series on my truck it was 2500 otd it has led lighting and remote unlock and lock..
do you have more pictures. that sounds expensive but dang it if im gonna get it I want it to look that good. I just want to see the fit and finish and a picture from the back of the vehicle. My truck is the same color I believe.
I just got my ARE Z Series canopy installed yesterday. Hopefully I'll find somewhere better than the garage to take pics this weekend. I also have the GMC branded Bedrug installed, but I don't have a pic of it yet.
Found a really good deal on a canopy, the only thing is it's for a 2006 gmc 5.8' box, does anyone know if it'll fit a 2014 with the 5.8' box?
EDIT: in case anyone is wondering, a LEER for the 2006 body style fits, but needs a little bit of trimming to make it fit properly.
By trimming what do you have to trim?
Anyone of pics of an older model topper on the new silverados?
The lip that come down from the bed rail needs to be trimmed down. Once I finish trimming it and put it back on my truck I'll post up a couple pictures
I appreciate it! I'm looking at getting a topper and don't want to pay the $1200 plus price tag for new.
Just had my ARE Z Series cap installed. Not very happy with the over all quality of the cap. It look is great from the outside, however the fit of the cap seems off near the front of the cap near the rear passenger doors. It bows out a little bit.
The cap came with 4 holes drilled into the part that sits on the bed rails. Dealer told me ARE shipped them this way to ensure it doesn't move around. Seriously? This company has been around forever and they haven't come up with another way to ship it?
The frame around the cheap plastic screen on the pop out window is fastened so tightly that the pastic mesh looks like it will be torn apart the minute I touch it. The screen is cheap plastic and bound to rip apart if anything bumps up against it.
The latches that the glass door closes and locks down on is PLASTIC!? And not aluminum as it should be. Dealer told me to be careful and that this is the first part to break with repeated use. Come on ARE....it's 2014 and manufactures in China can make this part for you.
I paid $2400 for this cap and I wish I went with the Leer one. I was told that this was the top of the line, best in class, etc....all bull crap. The cap is not worth the hype.
I'll post pictures of these issues tomorrow once it's bright outside. It's getting dark here and I want to make sure I capture these issues for everyone to see.
Not an ARE issue, but I need to put a weather strip on the tailgate. It's annoying to see daylight on the sides of the tailgate when looking out the rear view mirror.
Also tint on cap windows is about 30%. It's also much darker and view is limited, but not too bad. If you're planning on getting a cap do NOT tint the rear facing glass, you won't be able to see anything if you do.
I'll be getting the side windows tinted down to 5% to match the rest of the truck, but I will not be tinting the back window/door to the cap so that I can still see out of it at night.
See attached picture. I'll post some more tomorrow.
Sorry to hear. $2400 is a lot for a piece of turd.
Love my SnugTops. (3rd one). Best quality but you gotta pay dearly. $3500 for my XV.
  • 1 month later...
My Snugtop dealer called to tell me my Hi-Liner is in. I have some 10" tall bed drawers that have been in 2 other trucks. This time around, I wanted a taller camper. About 4" taller for the Hi-Liner. I know it won't look as sleek as a cab high, but at some point I have to go with the utility ahead of the looks. My main use is for bird hunting trips.
I ordered the side window/doors that open upward, which also have a small slider window to open when they are down. I had the roof tracks installed so I can mount my Foxwing shade.
I haven't seen this thing yet. I'm hoping it doesn't look too bad.
Finally got around to getting it put on today. Not the prettiest topper I've owned, but likely the most utilitarian.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
