OK, now that all suspension parts have "settled", I'm at 38.5" front and 39" rear. 1/2" lower in front, which is perfect IMO..... :thumbs:
  • Like 4
thought this might help .. I've been reading page by page to pick my tires (just did the pro comp 2.25 lift stock rear is .5 inch higher)
Tires
295/60R20 IMPERIAL
Section Width: 11.61 in
Rim Diameter: 20 in
Overall Diameter: 33.94 in
275/65R20 IMPERIAL
Section Width: 10.83 in
Rim Diameter: 20 in
Overall Diameter: 34.07 in
305/60R20 IMPERIAL
Section Width: 12.01 in
Rim Diameter: 20 in
Overall Diameter: 34.41 in
285/60R20 IMPERIAL
Section Width: 11.22 in
Rim Diameter: 20 in
Overall Diameter: 33.46 in
285/65R20 IMPERIAL
Rim Diameter: 20 in
Overall Diameter: 34.59 in
33X12.50R20 IMPERIAL
Section Width: 12.52 in
Rim Diameter: 20 in
Overall Diameter: 33.02 in
Tires
295/60R20 IMPERIAL
Rim Diameter: 20 in
275/65R20 IMPERIAL
Rim Diameter: 20 in
305/60R20 IMPERIAL
Rim Diameter: 20 in
285/60R20 IMPERIAL
Rim Diameter: 20 in
285/65R20 IMPERIAL
Rim Diameter: 20 in
Rim Diameter: 20 in
275/65R20 11.0 x 34.1
My post was so people didn't have to go online and type them all in ...
I understand but the are still more not covered in other wheel sizes... Its a good site for people to reference. the middle table gives you sizes around the one you entered.
Here is a link from that same site with every size listed out
http://tire-size-conversion.com/tiresizes/
Are you guys leveling out 2WD models? I want to get rid of the rake on my 2WD but don't know if I want to lift the front or lower the rear. Whichever is going to provide the best ride quality and not cause me any shock issues or pinion angle or anything.
I have my 2WD crew cab with a 2" level. Didnt notice much of a ride difference. I still notice a very slight rake but im happy with it.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
2.25" Ready Lift
Edit: Nevermind, just saw the tire size in the other thread.
Looks great btw!
Edited by Tim99GT
If you're going for ride quality, I would lower the rear. With the 2.5" level I have on mine, it is noticeably firmer in the front. Not bad, just noticeable.
Thanks for the reply. I definitely want to retain factory ride quality and reliability.
Mine's a 2wd. Did a 2" Fabtech level, shouldn't mess with any components and rides pretty much stock. I didn't notice much of a difference, if any really. The 2" doesn't completely get rid of rake, but I still wanted a little, so 2.5 would probably take care of it.
How do you like that 2" fabtech level? Is it aluminum? I also want a bit rake left when I get one.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   1 Member, 0 Anonymous, 1,159 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
