It feels better than the Goodyear SRA 275/55R20's thats for sure, more tire between the wheel and the ground is always better. I wish I would have got 18" wheels when I bought the truck. I"m not really a fan of the 20" wheels. If you want a slightly more aggressive look get the michelin LTX A/T2, they are great tires also.
Edit: MPG did not change
Your truck looks sharp. I would have worked a deal with you for a rim swap! I like the 18's and 20'son these trucks. I believe the overal height/diameter between the 2 are pretty close, too.
You are going to need to stick as close to 0 offset as you can. Mine are a +1 with 33's and no real rub.
What tires are you running and what rims? Are they 20x9s? Post some pics if you have them. I just ordered fuel mavericks 20x9 with +14 offset, now I'm wondering if I should cancel and order them with the +1 offset that they also offer
The front is about 1/2 inch lower then the rear now.
I love this 2" level kit, the truck feels so much better now. If anyone is on the fence about putting a level kit on, do it, you won't be disappointed.
For the guy who just wants the front closer to level, 2" is as high as I would go, you don't want to chance premature ball joint or CV shaft wear.
Edited by 14LTZZ71
2" Rough Country Level with Michelin LTX M/S2
That's the perfect look, exactly what I want.
Yeah, your truck looks just like mine except for the 20s and I have the 6.5' bed. I put the RC level kit on also. Truck rides great and gets many compliments from others. Edited by ShotgunZ71
Has anyone used the Belltech part #994 on there truck ? I'm interested in dropping the front just an inch and the rear 3 to get it closer to level. Thx
2.5" level, factory rear block and 295-60-20 toyo AT II
  • Like 5
Any rubbing with those 295/60r20s? What offset are your wheels?
Looks like you're just a hair higher in the front. Looks good though.
Anyone try the 2.5 RC level with just the bottom spacers?
Edited by Jay700
Yes I did just the bottom spacer and 2 inch block in the back I like it and got lazy now I've got the half inch spacers sitting in my closet collecting dust lol
Sorry I have been offline for a few days. Here are my Fuels 20x9 +1 offset.
Why do that on purpose? It's the same bottom spacer that comes with the 2" kit, correct? Plus the 2" kit is cheaper.
    • She's laughing all the way to the bank.
    • There's a new PI on 2023-2026 L3B shudder.  Possible faulty front oxygen sensor.   Dealer can pull up PIP6060A and give it a read.
    • Also here's the drive cycle for a 2021 Yukon with V8.  DO NOT USE THE CRUISE CONTROL WHEN RUNNING DRIVE CYCLE!!!!!:   Warning: Road test a vehicle under safe conditions and while obeying all traffic laws. Do not attempt any maneuvers that could jeopardize vehicle control. Failure to adhere to these precautions could lead to serious personal injury and vehicle damage. Note: You have completed this procedure when all parameters display Complete. Short stops for traffic will not affect the procedure. Note: Do NOT use cruise control during this procedure. Ignition/Vehicle » Off — For greater than 8 h Verify the scan tool parameter: Cold Start-Up = Yes If not the specified state Ignition/Vehicle » Off — For greater than 8 h & Repeat this step If the specified state Ignition » On / Vehicle » In Service Mode — For 1 min Engine » Idling — For 2 min Drive the vehicle while maintaining the following conditions for 20 min: Part Throttle Vehicle Speed = 24 to 97 km/h (15 to 60 MPH) Safely stop the vehicle Operate the engine/vehicle within the following conditions: Accelerate the vehicle to 64 km/h (40 MPH) Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 10% and 13% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 13% and 16% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 16% and 19% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 19% and 22% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 22% and 25% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Maintain steady state throttle at 89 km/h (55 MPH) — For 10 min Safely stop the vehicle
    • About the only GM that compares well with its competitors through the small to midsize vehicles is the Trax. I would like nothing better to just drive GMs. My wife in a Cadillac me in a Chevy minivan and Colorado. Part of my day is comprised of reading and watching comparisons of automobile. I could buy a car today. I’m back to research the next.
    • Do you have any DFM defeat devices like the Range modules?
