It feels better than the Goodyear SRA 275/55R20's thats for sure, more tire between the wheel and the ground is always better. I wish I would have got 18" wheels when I bought the truck. I"m not really a fan of the 20" wheels. If you want a slightly more aggressive look get the michelin LTX A/T2, they are great tires also.
Edit: MPG did not change
Your truck looks sharp. I would have worked a deal with you for a rim swap! I like the 18's and 20'son these trucks. I believe the overal height/diameter between the 2 are pretty close, too.
You are going to need to stick as close to 0 offset as you can. Mine are a +1 with 33's and no real rub.
What tires are you running and what rims? Are they 20x9s? Post some pics if you have them. I just ordered fuel mavericks 20x9 with +14 offset, now I'm wondering if I should cancel and order them with the +1 offset that they also offer
The front is about 1/2 inch lower then the rear now.
I love this 2" level kit, the truck feels so much better now. If anyone is on the fence about putting a level kit on, do it, you won't be disappointed.
For the guy who just wants the front closer to level, 2" is as high as I would go, you don't want to chance premature ball joint or CV shaft wear.
Edited by 14LTZZ71
2" Rough Country Level with Michelin LTX M/S2
That's the perfect look, exactly what I want.
Yeah, your truck looks just like mine except for the 20s and I have the 6.5' bed. I put the RC level kit on also. Truck rides great and gets many compliments from others. Edited by ShotgunZ71
Has anyone used the Belltech part #994 on there truck ? I'm interested in dropping the front just an inch and the rear 3 to get it closer to level. Thx
2.5" level, factory rear block and 295-60-20 toyo AT II
  • Like 5
Any rubbing with those 295/60r20s? What offset are your wheels?
Looks like you're just a hair higher in the front. Looks good though.
Anyone try the 2.5 RC level with just the bottom spacers?
Edited by Jay700
Yes I did just the bottom spacer and 2 inch block in the back I like it and got lazy now I've got the half inch spacers sitting in my closet collecting dust lol
Sorry I have been offline for a few days. Here are my Fuels 20x9 +1 offset.
Why do that on purpose? It's the same bottom spacer that comes with the 2" kit, correct? Plus the 2" kit is cheaper.
