Same kit as 14. Order 14 kit. Make sure u know if u have aluminum or steel control arms
Sent from my iPhone 6
using Tapatalk
Strange, I just ordered my RC kit, 1305 GM 07-15 2.5" leveling lift kit and was told no difference concerning the control arms.
thats because now they send u both set of bolts no matter what. U will see once u receive the kit.
Thanks, Been reading most of this evening, and just getting to page 65...
no problem. Mine is just the 2 inch leveling kit and rough country still ask before u order if u have aluminum or steel. Just FYI
I ordered the Rough Country kit, 1305 GM 07-15 2.5" leveling lift kit and upgrade my tires to Bridgestone Dueler AT Revo 2's, P275/60R20 which are 33" tall compared to my Goodyear Eagle LS2 which are 31.8. I will be loosing an inch and some in width (10.0 to 8.7 wide). One of the guys in the service department has 35"s on his 1500 with the same lift but I don't want to throw off the speedo too much... I would think there are other factors that would also be changed as a result of tire size such as shift points of the tranny etc... If I could just touch 34 inches tall I would be right in the sweet spot.
I do like the look of the wider tires on these stock 20 wheels but I need to check the wheel size. I believe these are 2013 LTZ wheels and should have 31 offset backspacing. My summer shoes also have 31 offset, 5308 Hollanders that come on the Tahoe, Avalanche etc... Decisions decisions...
Keep the photos coming in and don't forget to post your lift size and tire size with the photos. That really does help us guys on the fence!!!
I have a 2014 Sierra SLE with a 2.5 RC lift with the stock 1" block in the rear. I want to put 295/70/18. Will these work on my truck? I'm getting conflicting strories from the tire sizes. Some people say they don't rub with that size but others say they barely rub with only 33s. I little guidance would be greatly appreciated. Thanks guys. I'm a newbie to the site by the way. I've been getting a lot of good info from the threads.
https://www.youtube.com/watch?v=dwMfIp8uIXg
Ok, I took a the top .5 " spacer off the kit and I thought that would fix the issue. However the popping noise is still present and the awful creaking noise too. I tried to get a video of it but it's hard because it's raining and I can't press the gas (exhausts fault). You can hear it faintly in the video when I turn the wheel and when I pop it out of reverse/drive. It acts up even more towards the end. Turn your volume up high because it's not a super loud noise. It's much louder in the cab than on camera, but that should give an idea.
I re torqued some of the bolts, I couldn't get to the ball-joint bolt yet. At this point I'm considering removing the hold kit. Any ideas??
Ya I have tried also... Just keeps on working and never loads the photo.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 443 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
