I'm actually seeing all the current pictures posted here
Sent from my iPhone 6 using Tapatalk
Edited by TheFactor
Truck looks good. It almost appears as if the rear is a tad lower to me... I don't think I will go with that much of an aggressive tire look, at least for now. :chevy:
Yes, they're the bfg ko2 275/60/20
Nice looking tire !
And Truck ?
Edited by TheFactor
I am going to call around and get a price on a set of Bridgestone Dueler A/T Revo 2’s in size LT275/65R20's... I had the Revo’s on my last Ford truck (04) and they were great tires, unbelievable in the snow. I think they should fit just right with my Rough Country 2 1/2" level lift kit. If all goes well my lift will be installed on my birthday next week. Happy B day to me! :lol:
Does anyone think there will be a clearance issue? Going on my 14 Crew LT 4X4, not Z71. I believe the Duelers are 34.1” tall, and that will put her right where I want to be!
275/60/20 bfgKO2. 2.5 RC front onlyb12990e5014bb67302c5b584a6725c90.jpg
More pics to come, just had the tires put on
Sent from my SM-G860P using Tapatalk
Looks great, is it perfectly level? Or does the front sit up a little higher than the rear? Also is there any downside to not using the Rough Country 2.5 rear block?
I didn't use the block on my 2.5 kit and like it better that way. Mine sits level and rides great.
Reading up on some things do these kits seriously increase wear on your ball joints, cv joints, and UCAs due to the change in geometry? Some seem to be absolutely convinced it does.
Others not so much. Strange there seems to be such a discrepancy among truck owners. Given that leveling kits have been out for years. Figured had they been causing problems people would stray away.
Go with a 3 inch kit and yes they wear the joints. That's why the 2.5 kits is out. Keeps everything close to stock and still rides like new. If you have them properly installed and checked and greased no problems. I had a 4x4 with 100k miles and towed a toy hauler...no issues. But I also maintenance my vehicles like they should.
On my 2011 Silverado ran 70,000 on a leveling kit before I lifted it no issues. On my new truck doesn't seem much off from stock and actually looks less of an angle than I had on my 2011.
    d.lowrey
    d.lowrey
  • Who's Online   0 Members, 0 Anonymous, 3,260 Guests (See full list)
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
