I've had my truck on stands for a week over a couple things that went wrong, but It's on the wheels this morning and I'm heading to the alignment shop.
I picked up these King shocks from a member here (plus the rears). After some thought, I bought some Rough Country upper control arms to ensure the balljoint travel was adequate.
Last Sunday, I started this work to install the Kings and RC UCAs. After messing around to get the RC UCAs to fit, it became apparent, the front tube of the UCA was going to rub on the frame, no matter how much I ground off the frame. Poor design. More on that later.
I got on the phone last Monday to Cognito up in Bakersfield and ordered their UCAs. I called RC and got a return authorization.
I finished up late lastnight. I was trying to install the new Hellwig front bar, but ran out of gas and tossed it in the bed to take to the alignment shop to install.
I'll post on the ride later.
Very nice. How are those brakes working out? Better than stockers I hope. I am considering upgrading mine this summer or next.
Mike
The brakes are great. Definitely a great benefit for large tires.
It'll get you 2" of lift, but it's physically only like an inch thick…
So I got my new BFG KM2's on today now if feel like im in a truck again.
What lift and what tire size please... I like it!!! :thumbs:
2.5 RC Front only tires are 305/60r18
Any rubbing? ?
Slight rub on the sway bar at full lock. But was nothing the a 1/4" wheel spacer couldn't solve. Now there is plenty of room.
Put a Hellwig front swaybar on and it won't rub. Theres a slight difference for the better on the Hellwig bar. To hell with the spacer. Move forward, not backward.
Edited by spurshot
That's a knarly knobby. Way more tire than I can handle....I'm not worthy.
chrome_mo951_bfg_km2_35x12_5x17_002_zps7
Yeah they are awesome come in with 20/32s of tread depth. I ran 35x12.50 on my 2008 f150 crew for 36,000 and stil had 12/32s but I did rotate religiously. They ride great. A hell of a lot smother and quiter the the nitto mud grapplers I had on my silverado and Tahoe. Edited by JASLAR12002
    Sothpaw27
    Sothpaw27
  • Who's Online   5 Members, 0 Anonymous, 722 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
