Well hell when using their search engine i was putting 2014 gmc and all that came up was the 7000MT, if the quicklift loaded fits the 2014 chevy LTZ 4WD it should very well fit the 2014 GMC SLT 4WD should it not?
for some reason they say if your truck came with rancho shocks it won't fit. Did yours? My understanding it will fit z71 but won't give a full 2" lift. I could be wrong. A local company that lifts trucks is installing mine Wednesday.
i just entered gmc 2014 1500 4wd on go rancho .com and it pulls up the same quicklift loaded fits. Not sure what u entered
http://zoneoffroad.com/bad-to-the-bone?id=825
If you have not seen this I was looking at the 72 pages and found this on the zone site.
14 1500 with 2in level 35/12.5/20's
Would love to know if this works in the real world.
Tried to respond to your message but couldn't get it to work. Regarding my truck: No blocks in back, 2.5 inch lift in front that was dealer installed before I bought it, so I don't know what brand it is. Tire size is in my signature block on all my posts. Good luck with yours.
That should only be if you have an AT with the larger front rancho shocks
This is what I have been told and research has shown.
I finally got my tires in from tire rack and my motofab 2" level blocks in that I picked up for 39.99 on amazon. got the blocks installed alone in a little under 2 hours last Wednesday night, and got the 275/70/18 general grabber at2's mounted and the truck aligned up Friday morning. Really happy with how everything turned out. Didn't think it would look lifted but its very notable. Much more than I expected. I like the firmer ride and it actually feels like a solid truck to me now. I also removed the front air dam and coated the wheels with plasti as protection for the winter.
Would like to see a side pic of ur truck with the black rims.
I have a z71 and it came with rancho shocks. I entered gmc 2014 SLT 4wd and only get the 7000mt.
I highly doubt the leveling kit has to do with your truck hoping all over the place. If the Rancho Shocks are stiffer then the stock ones in will probably make your issue worse.
no I pull a trailer 5 days a week. Only does it when I pull because front is raised so much because of spacer. Just FYI
Sent from my iPhone 6
using Tapatalk
Spacer or Longer strut is the same......no difference :)
we will see. I'll be doing a review under my other thread. My last 2014 silverado I had leveling kit and air bags in rear. Still hoped in the front while pulling trailer only when I hit a bump. So going more expensive route by replacing whole strut and still giving it a level look.
using Tapatalk
using Tapatalk
So the front is hopping off the ground when towing your trailer? Have you checked the tongue weight and are you using a load leveling hitch?
I misread your post but the plasti info is there for anyone who needs it ha. I only have one other picture of my truck and its in my garage at an angle. Ill take a few side shots soon.
Truck looks great man! Thanks for the info on the plasti dip
when I would tow before a leveling kit it never hoped. Problem is I like the look of it level but when u tow it's not level anymore. It's not that bad. I'm not saying it just hope everywhere. Just doesn't feel safe when I hit a bump or go off road without a trailer. Just looking for something more durable besides a $65 RC kit that I have. Want something that is not going to wear all my other components so that's why I have chose rancho quicklift loaded. Like I've said. I'm getting it installed Wednesday so we will see how it rides. They have a 30 day money back guarantee.
using Tapatalk
The issue with any leveling method is the UCA balljoint angle of the OEM balljoint. When I installed my king shocks, I also installed Cognito UCA s with larger ball joints.
Wondering if i should do the same when i get bilsteins. I likely will for added assurance but it would definitely be down the road.
    B07
    B07
  • Who's Online   0 Members, 1 Anonymous, 835 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
