No, That one will work, but it's an unprotected Teflon socket on a steel ball that the racers use. My truck isn't a race truck. I don't want to maintain it like one either. I bought their, UCA with a regular automotive ball joint, albeit a heavier ball joint than the OEM.
http://www.cognitomotorsports.com/boxed-upper-control-arm-kit-715.html
Ok Thanks. Those arms look great! Did you install yourself?
Well i pulled the trigger on some Nitto Exo grapplers yesterday, they should be here sometime next week. Ill post some pictures once i get them.
Exactly ... thanks, it's just the look I wanted !
Keep your overall plan of future mods in mind when deciding on wheel size. When I bought my o/s Wilwood brakes, I was told that the min size wheel was 18" (although 17s looked like they might work) for the 14.25" dia brakes I chose. There was also a 16" brake for the same price that required a 20" wheel. So, if you think you'll get bigger brakes later, research the compatibility of the wheel sizes.
Will they fit? I am new to the forum. I need advice. I have a 2WD 2014 Silverado LT with factory 18" wheels. I recently had a Prolift 2" leveling kit installed up front. I have ordered LT275/70/18 Nitto Trail Grappler M/Ts to achieve a more aggressive look. They are 33.62" in diameter. My question is will they rub? Do I have enough clearance? I have read wheel well liner could be adjusted with zip ties. Is this an option? Could someone post some pictures of this? Thanks.
Your tires should fit. They'll be close in some places, maybe even rub the liner a bit, depending on the flex of the liners. But probably not. You'll be fine. And yes, you can tie back the liners. They're just plastic and you can drill a couple holes to run the ties thru.
Same setup I have but just a different tire. everything fits fine and they really fill the wheel wells nicely. Post pics when they're on!
Edited by ddanis60
Having the zone 2 inch level installed this morning at 10:30. Still undecided on perfect tire size. Won't be off road but want a better stance with no rub problems. So many options here on this thread. 2 inch level up front. Stock block in back. Using my stock 20's I need a tire choice that's gonnagive me more rubber without sticking out the sides. Thoughts?
EDIT: zone 2 inch with G2 285/55/20.
Edited by 14ChevySilveradoLTZ
show a pic
Sent from my iPhone 6
using Tapatalk
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
