Just go look. My truck hasn't arrived so I ordered the aluminum one and if the bolts are to long I'll grind them down a bit only 10 mm difference in length
I know I'm going to sound dumb, but I have a 14 Z71 Silverado and how do I know if I have aluminum or stell a-arms so I know which kit to order?
alluminum silver steel is black
Does anyone know if it is feasible to go 22" wheels with all terrain tires and a leveling kit on a 2014 Sierra SLT?
The only thing that would be affected by adding a leveling kit would be your camber and caster, which means you would maybe feel a bit squirly and have some darting on the highway.
Actually, with all the talk about ball joint wear, I thought perhaps so; however, it turns out that the only thing affected was the toe-in. Who knew?!?!
smaller%20alignment.jpg?psid=1
Camber definitely gets affected you can visually see it with spacer levels. The problem is that "spec" is a wide range and as long as it shows green on the computer they won't touch it.
Edit. I see your camber is negative that's odd I would have assumed positive.
Edited by projectsummit
The best way to tell is to use a magnet. If it sticks they're steel. If not, aluminum. There's no way to know if the factory suddenly starts painting the aluminum arms.
So I installed my MotoFab 1.5 level kit, now to see of I can fit 285/70 17 tires on factory wheels under there...
Interested to know if u can also
I'm installing a motofab ebay 1.5" level this week too, did it affect the ride quality at all?
Nope, rides like factory. I put mine on will 300 miles on my truck. YMMV
Me too!
I find that the 2" level makes the truck look nose high even the the wheel wells measure to be level. 1.5" I think will be perfect, it will have the same rake as a 2.5" level that comes with a block for the rear.
I have contacs at my local NTB, after work I'm going to stop by and see what they say, they have a 285/70 17 tire in stock, he wants to look and see if it will fit for me...
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
