Leveled today with Fox Coilovers. Also added rear fox shocks, 20x9 Fuel Assault +1 offset, 275/60/20 BFG KO2's, and a custom dyno tune :)
Does it ride better than the stock rancho shocks that come on the z71 package?
Sent from my SAMSUNG-SM-N910A using Tapatalk
Edited by 440hsp
That looks really good! I bet it rides like a dream now.
It sure does. Much more composed than stock. I only put about 50 miles on it since I picked it up today. I plan on taking her out tomorrow and pushing to see how significant the difference is :)
Josh
Absolutely better. I have the all terrain edition which includes everything in the Z71 package and I'd say the Fox is a huge step up. I plan on pushing it tomorrow to really see.
Josh
Doing my first ever level next week. Is it better to do shock upgrade when put level on or can it be done (relatively) easy at anytime? If the 2.5" level makes the ride real harsh may have to look into adding fox shocks on rear
I had a 2.5" RCX level installed on my truck after first bought it and I opine, the ride quality to me really didn't change very much. So I would just install the kit first and see what you think before potentionally wasting money on shocks if they aren't needed.
After spending days reading this thread, I went with the ReadyLift 2.25" level kit. Everything is now 39" on my new 2015 Midnight Edition. Keeping stock tires and rims (just 500 miles on them).
Thanks everyone for all the info!
Was this the 66-3085 kit from Readylift you installed? I just also took delivery of a '15 Midnight Edition Crew Cab and want the same look as yours.
Edited by SheeB
Yes it was the 66-3085.
I was thinking about going with the 5100 Bilstein adjustable shocks to level my 2014 silverado z-71, the info I found on them says they provide a 0-2.5 inch adjustment in ride height. Any info would be appreciated.
They are 0-1.8" sounds like most people get 2" with them but I tried to order some about 2 weeks ago and a few places told me they are back ordered until end of October if you find some let us know good luck!
Thanks for the info, z-71 chevy. I will let ya know if I find some.
2015 Z71 Silverado 5.3 V8
Bilstein 5100 adjustable strut 2" Level Front
Bilstein 5100 Rear Shocks
Toyo Open Country AT2 275/65/20
MHT Fuel Nutz 20x9 wheels
Magnaflow 18" Dual Exhaust
Zero Rub
Couple of pics including a Before and After
I don't mean to ask stupid questions... But is the billstein setup better than doing an RC kit? Ride was and cost wise? This is my first truck and I'm trying to not screw it up lol. Your truck has the setup I'm looking for!!
The issue is it cost more and they are on back order. So you have to factor that in to what you think is better. Guys with bilatein will have to comment more though
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
