I know I like it! That's a good looking truck for sure.
Thank you guys, I am thoroughly enjoying every minute.
So I went with a 2.5" level lift and for tires I went with Toyo Open Country M/T 275/65r20.
So I'm new on here, but without reading ALL of the 181 pages, I've noticed that most people are using 20 inch rims, and have used tires such as 305/55/20 or 295/55/20. I have a 2014 Chevy Silverado with stock 18" rims. I'd like to just use the stock 18" rims, and then get leveling kit, and new aggressive grip tires. If I go with a 2.5" leveling kit, can I get tires such as 305/65/18 or will I have to go a little less taller with something like a 305/60/18? Does anyone have something similar to this on their truck? If so, can you please offer advice, comments, and/or pictures please. Thank you.
Is there supposed to be a difference in bolt sizes for leveling kits for the aluminum and steel control arms I ordered a moto fab 2 inch leveling kit and I read somewhere the steel control arms require a 80 mm bolt
I wanted to do the exact same thing. I got the Rough Country 2' level and put 305/65/18 BFG All Terrains on my truck. No rubbing at all - it looked great. So a 2.5" level should work great.
Phone pic of my 2014 High Country with 2.5 RC level and 12.50/33/20 Federal Couragia MT
Good looking truck. I just picked myself up a 2015 1500 High Country as well. How well do the 33/12.5s fit with the 2.5 level kit? Any rubbing? Any issues using those stock rims? I had 305/55/R20s on my Tahoe that I just traded in and had some trimming to do with the Rancho quicklift installed. I was initially thinking of just going with a 33x11.5-ish tire with the stock wheels. Any issues with pinion angle or steering geometry with the leveling kit?
7473330315x65.jpg How will a leveling kit do with these factory 22" GM wheels with 285/45/R22's? I want a more aggressive off road tire that has more sidewall, but not sure what the best size would be for the 2" level lift. Any advice is appreciated!attachicon.gif7473330315x640.jpg
i had 305 35 24's on a 10" wheel on my 2014 with 2" rear lowering shackles and no problems. what you are wanting to run is both narrower and shorter so you should be fine
Thanks for the info. Do you happen to have any pics of your truck? I'd like to see how those tires look on it.
Here are 2 pictures with the Rough Country 2" Level with Bilstein front adjustable shocks set on the lowest setting. BFG All-terrain 305/65/18
truck 2
Thanks for the pics. Truck looks good!
How did you put on a leveling kit with the sensors for the shocks on the front? Did your lift kit have lowering brackets for sensors? If so what are they and where did you get them. I have a Blue Denali 15 model I want to level. Thanks!
The level kit does have relocator brackets for the semsor mounts. Super easy install. I was impressed, rides the same.
The 305/65/18's that were posted look really great. I'd say that's probably about the max size, without doing any trimming. Some other popular sizes to consider with a level kit are 275/70/18, 305/60/18, 285/65/18, and 33x12.50x18.
I'm thinking about these exact tires for my winter set. Do they rub the sway bar at full lock in either direction?
hello guys. New here. I'm needing help verifying if a 295/70/18 on stock wheels will fit with a 2.5" front leveling kit on a 2015 midnight edition
I'm running those on a 2.5 level and 1.5 body lift with stock z71 wheels and they rub sway bar and liner
ok thanks for the info. I think im gonna go with 275/70/18 stt pros as I am not doing a body lift and this is my daily driver and I want zero rubbing.
    • There's some truth to the above, but also, she's selling fullsize trucks and bread/butter CUV's like hotcakes, meanwhile, extracting GM's pickups from the deep discounting sales game.   GM's stock has held its own during her tenure, and the more recent buybacks are delivering cash back to investors and signal confidence in their direction forward. Even with the EV losses.   GM is an example of a modern publicly traded company. The #1 goal of any publicly traded company is to deliver the most value possible to shareholders. Despite being a car company, building the best car isn't GM's path to delivering maximum shareholder value.   McDonalds doesn't make the best burger, or the best coffee.   I've mentioned in another thread, I really don't / won't ever understand Cadillac or Buick in a modern context. Both brands are completely dead to me. I'll cede that the Escalade is a nice SUV, but the brand and nameplate mean nothing to me, and GM will never persuade me to pay north of $170k for a gussied-up Tahoe or Burb. Other people don't mind doing that and that's their purview.   The C8 shares absolutely nothing in common with any other current Chevrolet or Corvette on the market. Since its introduction 8 years ago, it's developed quite the following. It did what other Corvettes couldn't do: reduce the average age of its buyer. GM has something there, and I see them investing in the car. They'd better not mess that up.   We've successfully derailed Grumpy's thread again, but I think this one is meant to be more of a random thought thread so a little wandering is probably OK.
    • Sliding doors ftw   Also, Sienna ftw as well.  The in-laws got a 2024-2025 recently when their 2019 sienna was totaled due to a deer back in June.  They've been getting 38-40mpg on the 65mph highway they live on.
    • Forgot to mention that this started after changing the oil I use mobile 1 full syn with mobile one filter but I did add pro lube additive and was the first time doing so and is making me wonder just can't see why that would matter
    • I apologize for long post put going to try to explain everything. Parts replaced so far: Cam sensor Crank sensor Cam phaser valve Cam phaser solenoid Fuel pump Maf 1 injector Pcm Pdm   So about 2 weeks ago coming off the highway my 2007 yukon xl with the 6.2 stalled and would restart. Had unit towed back to house and I messed around with relays and unit started. Drove it the next day and same thing. Had it towed again. Scanned unit and had code p0300 with misfire data showing mainly cylinder 7 but I know that won't cause a no start. Measure fuel pressure and found only 42 psi replaced pump to have unit stall again and not restart. This time I stayed on back roads and just waited for it to restart about 30 to 60 min. During this time I found I have no injector pulse but have good power at injectors. Started unplugging 1 injector at a time and found when unplugging cylinder 7 pulse came back so i changed injecto and same issue. Turns out unit just happen to ready to start at that time. Scanned into unit and found no reason for the pcm to take away injector pulse so I replaced the pcm and same issue. I figured timing sesnor controlled the injector pulse so I replaced both sensors and while I had the water pump of i replaced the vvt components while i was in there. Read multiple people have luck chaging the maf for this issue so I changed it. Unit still stalls to this day and loses injector pulse on the ground side when it does. Have noticed watching the live data the pcm is request injectors to fire via injector pwm value. I have redone the ground wires at the left bottom of the block knowing this was the ground location for the pcm but still no luck. I am a mechanic by trade but this is having me pull my hair out. If anyone has something to have me check I will gladly im not much of a parts thrower but im about to load the cannon
    • Actually.  Wait.   I just re-read your original post.  Are you talking from INSIDE the truck you have to hit unlock?  Or from the key fob?  I had assumed from the key fob.   IF you are talking the inside unlock button, I assume you are shifting to park and its not unlocking the doors?  If so, that is changed via the settings page in the radio.  Go to SETTINGS, then VEHICLE and then it should be under LOCKS or DOOR LOCKS or something like that.
