Wanting a leveling kit for my 2015 and didn't know what I should go with 2" or 2.5". Also with a 2.5" do you have to go with blocks in the back and if so would it void your warranty?
The 2.5" Rough Country level comes with a block for the back and it shouldn't void your warranty
Does anybody have torque specifications for the suspension components that are affected with the 2.5" RC level?
Also, has anybody used the unlimited alignment from Firestone?
I never had good luck with Firestone here. Maybe due to my car being lowered. Lol
Sent from my SAMSUNG-SM-N910A using Tapatalk
Do I have to install the rear blocks if I go with the RC kit.
You do not. There are many people on here that are only running the front. You can also call Rough Country and buy just the front pieces for the 2.5" front lift.
OK thanks a lot for all the help now just to decide if I want 2" or 2.5"
If it helps any I have the 2.25 inch procomp front only and I sit just a smidge higher in the front. Can't tell by looking but the tape doesn't lie. I know results may vary but on my truck 2.5 would have been noticeably nose high.
Sent from my Note 4
It really just depends on how you plan to use your truck. If you plan on hauling or towing anything of considerable weight I would definitely get the rear blocks. I have Bilstein's in the front only and, when I was hauling my buddy's rzr the ass end sunk really bad. The rear blocks will help the appearance of this but I would look into other alternatives if I was to get a rzr.
Ok Guy's I'm at wits end here, I've got a 2015 GMC Sierra Denali 1500 4x4. I had a 2.5" level added to the front and the truck sits how I like it. Almost near level. I tow a boat often and the rear sags so I tried the Roadmaster Active Suspension to eliminate squat but not happy, it did not help at all or not enough to notice . Seems very bouncy. Was gonna go the Air Bag route but they do not offer a kit for a 1500 with Magnetic ride shock system. What can I do to the rear end to help? was thinking maybe a 2" block? add a leaf? The truck suspension seems to soft and I am limited on choices to to the magnetic shocks. Any good suggestions sure would help
Anyone with the RC 2.5 kit doing alignments after the install? Im hopefully going to install mine soon, just wanted to know if i needed to schedule a apt to get a alignment done.
Yes, I had my dealer install my kit and do the wheel alignment... because I care about my tires and want my 43K investment to preform at it's best.
JMO...
Go to etrailer.com and look at their products for suspension
2015 Sierra SLT
2 inch RC leveling kit
295/55/20 Nittos, no cutting, trimming or rubbing
Hey guys, I need some help on what tire size to run. 15' silverado crew cab. I have a 2.5 RC kit on its way in the mail. I plan i running a 20x9 +1 offset Fuel Maverick wheel. I want the lower offset so the tires sticks out a little bit. I like the look IMO. My question is what tires should I run if thats the wheel I go with? Been going back and forth between 295/55/20 and the 305/55/20, or should I just go with a 33x12.5? The two tires Ive decided on are Toyo MT/s or the Nitto Trail Grapplers MT. What do you guys think would be a perfect fit. If its possible I want to go with the larger tire but I dont want to deal with the rubbing.
I run the Nitto 295/55/20, they ride really good but they do make a little road noise as expected with a M/T the Toyo 33/12.50/20 is right at the same size, mine don't rub any and iv never cut or trimmed anything, I run the 2 inch leveling kit and have zero trouble, the best way to get the tires to last is rotate them every 3,500 miles, friend of mine gets 45-50k miles on his Nittos and that's all he ever runs, they're on a 2500 too, but he rotates them religiously
Decided to go with 275/60/20s on the KMC D2s 35 offset. No rubbing, ride height up front is roughly 39 7/8".
Finally got the leveling kit installed. I also installed some AMP powersteps with the plug and play kit. It doesn't sit perfectly level though, it's a 2.5" RC kit.
Did you install the rear blocks with the kit? Are those the stock tires in the picture? I'm wanting to order my kit now, just trying to decide on what tire to buy.
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
    • The Allison 10 speed torque converter doesn't "lock up" like the previous transmissions. It has 4 operational modes; open, slip, transition from open to slip; transition from slip to open. I have an Edge CTS3 monitor and I monitor transmission torque converter slip. Step on the gas and you get a little slip. Take your foot off the gas and you get a little negative slip. I have not found a way to display the torque converter mode beyond that. My Edge CTS3 also displays something that our trucks should already display, the current gear. I also monitor throttle body position and engine load. If I see the engine load getting too high, I'll manually drop a gear.
    • Nice result. Your filter is working well  I'd have like to have seen the acid number for this sample. Curious type that I am.
