Check your clearances in front of the tire at your UCAs. I'd bet they hit there too. Have your wife hold it to full lock or bungee the steering wheel to full lock...you can't hurt the electric steering. You won't be full lock often, so it's not a big deal if it's a DD. It's the off-roading and especially towing that lack of clearance gets you in trouble.
Nice looking truck. I don't like side bars either but need someway to get into the truck!
Thanks for the info I'll have the wife help me do that.
Yea it's a dd for now. Won't be towing anything either any time soon
It's not bad without those bars! Easier than my dad's old f350 anyway.
Sent from my Nexus 6P using Tapatalk
with the rough country 2.5" lift, does it matter the type of control arms (steel vs aluminum) when I order? Is there a specific kit for steel vs aluminum?
Pro Comp 2.25" Leveling Kit w/ Cooper Discoverer STT 33X12.5R20. No rubbing issues. Sorry for horrible picture quality.
Removed Front Air Dam:
Removed Factory Flaps:
After installing the leveling kit I noticed that the truck sits higher in the front. So I measured the front vs. the rear and found out the front sits 0.5" taller than the rear. I ordered Pro Comp 2" blocks and U-bolts. Which arrived today, and I will be installing those this week.
Very nice rig. I've got a 2014 High Country stock 4wd. I want a 2.5" kit without modifying the rear. Have you noticed any changes in the handling when pulling a trailer with the truck slightly nose up? Do you have any pics with the stock read block removed and the 2" block added?
Can you explain more on the topic of towing and the lack of clearance getting you in trouble?
Thanks, I have recently sold that truck. I will say after installing the rear block the truck pulled our boat much better. I don't have any pictures of the truck with the 2" block added, however, it only made the rear end of the truck only sit about 0.5" higher and wasn't noticeable at all. Which helped when pulling a trailer and not being so nose high.
I hope to be leveling out the new truck soon. I know have a 2016 Sierra Denali.
Go to their website and see for yourself.
2.25" ready lift level, 295/55 nitto trails
Do you sit high in the front or back? Also, did you add rear blocks in replacement of the stock blocks? Thanks
Yes it matters which u order. I can't remember the product code numbers though...
Just ordered RC 2.5 leveling kit. Plan on putting 285/65/R18 tires and method racing double standard wheels. What offset will i need on the wheels?
That size will work with stock offset (+24), so anything from +24 to 0 will work. -6 might work. -12 might be pushing it.
When you tow, you have to take your turns really wide which causes you to be at full lock a lot. Also, backing up a trailer requires a lot of full lock maneuvering.
Cool, thank you!
Cool, thank you!
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 795 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
