slevitt3335 Posted April 20, 2016 Posted April 20, 2016 2.5 rough country level w/ 285/75/18 toyo ats on stock Sierra wheels. Any rubbing with that size tire? I'm looking at doing the 2.5 RC on my stock 18's as well. Was thinking of the 275/70 18s
Aaron1085 Posted April 20, 2016 Posted April 20, 2016 In case anyone is looking for more data points on lifts, wheels and tires. I had a 2.5" Rough Country Level/Lift kit installed... and then installed 295/55R20 Toyo Open Country ATII Xtremes, with Fuel Maverick 20x9 Wheels in a +14. After having it done... I should have gone with the +1 offset... which would have stuck out an extra 13mm's, which is .5" inches. I would have loved to gone 305/55R20's... but I wanted to keep the Chevy mudflaps... and they would had to of come off. The 295/55R20's fit with an 1" to spare! Let's see
Daryl LBZ Posted April 20, 2016 Posted April 20, 2016 2.5 rough country level w/ 285/75/18 toyo ats on stock Sierra wheels. At first glance that looks like a 2500. Looks good.
dieselbeef Posted April 20, 2016 Posted April 20, 2016 so to make a long story short..ive wore my eyes out reading the headlight threads already..now onto leveling it. which kit is a front leveling only that isn't just reaming down the torsion bars or wont have the upper control arms hitting the frame at full extension. I have a 15 crew 2wd. sle. just like it to be level ..maybe even by removing a rear spacer? thanks
wheezy Posted April 21, 2016 Posted April 21, 2016 Hey guys I am trying to go for this guys build (link below) although maybe a little less aggressive tires (ill take suggestions I want an off road look but don't want damper daily driving, because its really never gonna go off road just like the look). Also is there any difference between the 2014 1500 high country and the 2015 high country? https://www.customwheeloffset.com/wheel-offset-gallery/8223/wheel-offset-2014-chevrolet-silverado-1500-aggressive-1-outside-fender-leveling-kit-custom-rims
jrob56 Posted April 21, 2016 Posted April 21, 2016 so to make a long story short..ive wore my eyes out reading the headlight threads already..now onto leveling it. which kit is a front leveling only that isn't just reaming down the torsion bars or wont have the upper control arms hitting the frame at full extension. I have a 15 crew 2wd. sle. just like it to be level ..maybe even by removing a rear spacer? thanks No torsion bars on these trucks. Cheapest option and what your probably looking for any front spacer kit, try Motofab, Rough Country etc. They are all pretty similar. Either a top or bottom spacer, some are a combination of both once you go above 2.5ish inches. Next option is Bilstein 5100 leveling shocks. Most expensive is Fox, King coilovers etc. Hey guys I am trying to go for this guys build (link below) although maybe a little less aggressive tires (ill take suggestions I want an off road look but don't want damper daily driving, because its really never gonna go off road just like the look). Also is there any difference between the 2014 1500 high country and the 2015 high country? https://www.customwheeloffset.com/wheel-offset-gallery/8223/wheel-offset-2014-chevrolet-silverado-1500-aggressive-1-outside-fender-leveling-kit-custom-rims No mechanical difference for leveling, wheels etc 14 to 15 that I know of. Id just copy what you see there. As for tires those are MT(Mud Terrains) if you want less aggressive go to an AT(All Terrain). Most popular are BFG KO2, Toyo Open Country AT2 , and Nitto Terra Grappler.
gman2015 Posted April 22, 2016 Posted April 22, 2016 I have a 2.5" Rough Country Leveling kit... with 2.5" in the front and the 1" spacer in the back... and had no issue installing 295/55R20 Toyo Open Country AT2 Xtremes on Fuel Maverick 20/9 +14 offsets.
jrob56 Posted April 22, 2016 Posted April 22, 2016 thanks..spacer kits are easy enough Removing rear block is an option as well. Think I saw a 4wd guy do that somewhere on here.
wheezy Posted April 22, 2016 Posted April 22, 2016 So the suggestion (from the company) is to go with 305/55/20 BFgoodrich all terrains KOs on the 20x10 -24 fuel mavericks, everywhere I've read 305s aint gonna work with a 2.5 level?
wheezy Posted April 22, 2016 Posted April 22, 2016 I have a 2.5" Rough Country Leveling kit... with 2.5" in the front and the 1" spacer in the back... and had no issue installing 295/55R20 Toyo Open Country AT2 Xtremes on Fuel Maverick 20/9 +14 offsets. what did ur wheels and tires cost you if you don't mind me asking
wheezy Posted April 23, 2016 Posted April 23, 2016 thats not bad, anyone running 20x10 -12 offset, if so is the rubbing bad? or just some slight trimming?
Pigster Posted April 24, 2016 Posted April 24, 2016 (edited) Does Anyone know the fender height on a 3.5 level running 33's?(2014 Silverado LT) Edited April 24, 2016 by Pigster 1
WillDiet Posted April 25, 2016 Posted April 25, 2016 I'm looking to do this exact set up. Feel free to post more pics. Looks perfectNot the best, but at least it's not in the driveway. I love the final product. Sent from my Nexus 5 using Tapatalk 1
Register a new accountSign in
