Do you guys know if a 33x12.50 tire can be run on the Silverado with just a leveling kit?
2016 Silverado LTZ Z71.
OEM GM 20x9 +24 offset wheels. Clear coated PVD Black Chrome.
Nitto Terra Grappler G2 285/55-20.
Bilstein 5100 Ride Height Adjustable shocks on highest setting. No rubbing. No trimming.
2014 Lt 3.5in Rough Country, 305-55-20 Destinations, 20x9 Moto Metal 970,
What offset did you go with on the 970s, +18 or +00
Well this sucks, I called the dealer I just purchased my 2016 Silverado from to ask them what they charge to install a leveling kit. They quoted $160 in parts, $230 in labor and $84.95 for a front end alignment. When I told the girl I will just bring it in for an alignment after I install the kit myself, she dropped the "that will void your warranty" bomb on me. Really?
I bought my Silverado this past weekend and they told me the same thing....
Why do you expect them to say? Yeah alter the truck and we'll still take care of it!
Sent from my SAMSUNG-SM-G930A using Tapatalk
I've had plenty of cars in the past that I was able to mod and not void warranties. I also never said I was mad about it and was only responding to the other post above mine. I also understand Chevy's stance on warranty issues on suspension and engine pieces, and that is fine. However if a person were to have a leveling kit or anything else done, and it is by a competent shop, then you would think that they would be a bit more friendly towards it. Enjoy your day.
Basically this rubbed me the wrong way. My last truck was a Ford with a 6.0 Powerstroke. God knows all the problems with that engine. My service writer at Ford had no problem with the fact I was running a programmer. This kinda pissed my off as far as my new chevy dealer is concerned. And yes, basically because I told them I would install myself and not pay them their high fees. Just tell me one thing. Has Chevrolet denied everyone warranty who went off and installed these huge lift kits and put on huge tires???
Chill out bro you take things the wrong way.
THEY ARE +00
Any pics down the side?? The other pics make it look like they are sucked in a little when they should be flush or a little outside the finder. Thanks
I leveled the front with a 3" kit from CCm Offroad (The kit I used fit 2007-2014), I also have air bags in the back I tow a trailer and didn't want the back to sag. the tires are cooper neon ltz 305/55r20
I also painted the center caps of the rims to match the rims. De badges and tinted the windows.
Looks good. When you debadged the truck did you remove the chrome door strips? Any difficulty?
I can prolly put some on today, they are not flush, there is some outside the fender
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
