This is a great picture. I was under the impression that a level up to 2.5 inches was safe. Your picture shows a very unnatural angle from your UCLA to your knuckle. This is what you would expect it to look like while your wheel is falling into a deep pothole! I would like to see before and after pictures of various level/lift modifications. Would a 1.5 inch look "more natural" and a 3 inch look worse?
Yes
Tyler
Did a 3" MotoFab level to mine with 33"s. I love how it turned out but I'm having alignment issues.
Edited by DonkeyKiller
What alignment issues? I have the same 3 in kit. Mine aligned fine.
Sent from my Nexus 6P using Tapatalk
The truck was pulling to the left after the level install, I had it aligned and now it pulls even harder but to the right. Guy at the shop said it was in spec and gave me this printout. Thinking of taking it to the dealership and seeing if they can do anything.
IMG 20160523 123200
I had the same thing. The first one whined and moaned about a level even saying a 1 inch levels bad. Had him align it 2 times and the steering wheel looked like / that. Took to another and he aligned it first time perfect. Plus the second guy asked who did it cause the toe was so f'd up from the first guy
Well that's good to hear. He seemed like he didn't want to mess with it just told me it was in spec. I guess he got me for $60. I'll find someone that will do it right.
So I put a rough country 2.5" on my 2016 AT up front, nothing in the back. I also have 295/60/20 on stock wheels. I was looking at the angle of my control arms at the end and it seems pretty steep. I was wondering yalls opinion? Would new control arms fix this or what? What are the long term consequences of this?
That angle is crazy steep looking! I have the RC 2 inch front only and its not even close to that! Do you have other mods? Different shocks?
RC is a small resin "clip" spacer installed on the bottom of the strut. The cheaper levels are usually this type but aluminum.
Pro Comp and Readylift are billet spacer rings that mount on top of the strut.
Bilsteins are a whole new strut with adjust-ability of height.
I was just reading and found this interesting.
Is there a consensus that the resin/poly (RC) spacers are "better" quality then the "cheap" aluminum (Motofab) spacers?
Just wondering.... When discussing a simple component such as a lower strut spacer, I'd think the aluminum is sturdier than resin.
I meant the cheaper spacers are the lower strut type. Other than RC, most are aluminum. Neither the alum or the poly type will likely ever fail. Could use a stack of washers and still not likely ever see it fail. (NO, I am NOT recommending that)
Edited by z71camaro
Copy.
I bought the aluminum motofab, 1.5"
Just making sure before I install them.
Thanks
No, just RC 2.5 in the front. and 295/60/20s on stock wheels. Everything else is stock.
I'm trying to decide when I should go ahead and get the new control arms.
Largest tire I can fit with a 2" level on stock GMC 18" all terrain wheels? The more rubber the better.. I think I saw a lot of 275/70/18? I'd like to avoid any trimming.
Edited by chevydeth
I have a 275/70/18 BFG KO2 on mine with a 2" level with absolutely no rubbing issues at all.
I've seen 297/70/18 on 18" method wheels, they have a +18 offset though instead of the stock +24ish
And that required trimming of the felt liner.
Thanks, you have any pics of your setup?
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
