I was wondering if you can install the ProComp kit with just the top spacer? And if so around how much lift that would provide?
Yes. That is exactly what their 1.5" level is, just the upper spacer. Brought mine up around 1.75".
I asked this previously but no one really replied.
Whats the difference between these lift kits besides brand and price difference.
RC is around $50 for just a 2" level but pro comp and blistein are $150+?
***(before i get some smart ass answer, this is a genuine question as i know absolutely nothing about these companies & products, what they offer/do besides "level & lift)
Galaxy Note 4 Using Tapatalk
Thanks! I bought the kit from someone who never installed it but really wasn't looking for the full 2.5".
RC is a small resin "clip" spacer installed on the bottom of the strut. The cheaper levels are usually this type but aluminum.
Pro Comp and Readylift are billet spacer rings that mount on top of the strut.
Bilsteins are a whole new strut with adjust-ability of height.
Thank you very much
Edited by quise2024
Did you go online and look at the difference? There are different leveling kits from each company. Pro comp has both aluminum and poly and it looks like they just make a spacer for the top of the strut. RC is a poly spacer for the bottom of the strut, but they also make a full 2.5 level kit that has a bottom poly spacer, a top poly spacer, and a new block and rear Ubolts for $150. There are also 3.5 levels that include UCAs and drop kits for your differential.
Any of them will work but if you are just looking for a 2" level, don't be fooled into thinking a $150 piece of aluminum at the top of your strut is any better than a $50 piece of poly for the bottom of your strut. There are thousands of trucks running both and I have not heard of a single failure of the bottom poly spacer.
For anyone that's interested I installed Fox 2.0 Coilovers up front at the factory set position (about 20 threads up from the bottom/ see photo)
With factory steel suspension and LT285/70R17 BFGoodrich KO2s tires (at 38PSI), the distance between ground and fender is approximately 39.75"(after driving about 500 miles).
Here's a couple photos showing the angles:
My next step is to install the Cognito UCAs sometime in the next couple of weeks once they come in.
2WD Z71?
Last night I installed the Rough Country 2.5" lift on the front only and today put the MM 20x9 -12 with 305/50/20 Zeon LTZ on and could not be happier the the look or the ride
Perfect example of why these trucks need rear blocks or air bags when you level them. Put a little weight in the back and they squat and point the headlights to the stars.
Air bags this week!!
I love the look of my 2.5" RC level kit. Installed about 7500 miles ago. Had factory 18" wheels on truck until yesterday. Took truck down to tire shop to get new 20" wheels and tires installed. They informed me that my upper balls joints had some play in them, Truck only has 20,000 miles and level was done at 14,000. Not very happy about that, I think my next step is to go with a different lift. The level kits just cause too much wear and tear and in my opinion do not ride very well. Would like the Bilstein struts 5100's I think..? but not sure if I can get as much lift out of it...? I love the stance of truck now and don't want it too high or any lower. Went with BF Goodrich KO2 275/60/20 on a set of Fuel Vapor Machined 20x9 rims with 24mm offset. Looks great and no rubbing.
Just upgrading shocks(going to 5100s for lift purposes) will put the same strain on the exact parts the level did. You are altering driving and cv angles, consider going with a kit that corrects driving angles and lessens the strain on tie rods/ball joints. It's worth the investment if you have to put a $500+ ball joint and labor in the truck every 5-10k. I believe there are 3" lifts out there which would yield you around the same stance as you currently have.
Edited by tanner709
This sounds crazy, ball joints worn out in 6k miles. Id get another opinon or check them yourself before you worry too much about it.
It does sound crazy. I walked to the rack and physically watched them wiggle the tire from top to bottom. The play is not terribly bad yet or dangerous as the mechanic said, but just wanted me to be aware as I just invested $1300 in tires and could potentially cause tire wear down the road as it gets worse.
    • I am in the market for a bidirectional scan tool so was hoping someone can help point me in the right direction. There are so many options out there it is hard to narrow down which make/model to choose.   I have always done my own vehicle work so looking to maximize capability with the scanner. Ideal price is $1k or less but would be willing to exceed if it opens up significant benefits.  Currently my 24 2500 is the newest vehicle but also have a few mid to late 2010s Subarus as well.    It seems that the Autel MP900 has a decent amount of features at a reasonable price?
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
