Hope these pics turn out a bit better. Just got window visors today. Trucks not shining but ya get the idea. 1.5" motofab, couldn't be happier
Do you have any before pics of your truck? Looking at a 1.5" motofab as well.
In case anyone is looking for more data points on lifts, wheels and tires. I had a 2.5" Rough Country Level/Lift kit installed... and then installed 295/55R20 Toyo Open Country ATII Xtremes, with Fuel Maverick 20x9 Wheels in a +14. After having it done... I should have gone with the +1 offset... which would have stuck out an extra 13mm's, which is .5" inches. I would have loved to gone 305/55R20's... but I wanted to keep the Chevy mudflaps... and they would had to of come off. The 295/55R20's fit with an 1" to spare!
I just put a 2.5" front level on mine w 305 55 20. They rub slightly at full lock. I'm 1" high in the front so thinking of putting on a rear 1-3/4" block and remove the 1".
RC 2.5" with block. Amps and Tires coming soon
Good looking truck. What size tires? I have a 2.5" level on the front and stock block in the back. Measuring from the ground to the center of the fender, I'm 1" high in the front. So my thought is by adding the 1-3/4" block in the rear, it will put me close to dead level. How does your truck measure out with the rear block?
2014 High Country 6.2L 4wd
2.5" ProRyde front level 305 55 20
Amp power steps
Adding 1-3/4" rear block because front rides 1" high cdf396732bade5401c0e334289f748f3.jpg87e06e296650ac7211e7e81ab2dad484.jpg
1.5 Moto fab is the way to go. Perfect level.
Looks great.
IMG 0291
i just put the RC 2in level on my truck today and its not sitting the way i would like. do you guys think it would be safe to put the motofab .5in level on top mount?
Edited by tmendoza115
What don't you like about it? It looks level to me like all the other trucks that put 2" or less in the front. If you add .5 up front, it might look front-high. I didn't like mine with the 2.5 in the front so I added the taller rear blocks the same day. I don't mind a little rake, but I can't stand a low looking 4x4.
It still has some front end rake going on, it's temporary until I do a complete suspension lift. Just wanted to know if it was safe and wouldn't put a strain on the ucas
I have same issue. I went 2" level and still have rake. These truck need 2.5" IMO, to fulfill my desired look. I HATE rake! It seems most everyone on this site prefers rake. If that was my thinking, I wouldn't bother adding any leveling device.
Anyone have a clue how these guys are fitting 35s with just a level? I'd hope a dealership isn't selling something that rubs like crazy. I sent a note via eBay asking about rubbing and got an instant response saying if I was interested in buying I could call and ask.
http://www.ebay.com/itm/GMC-Sierra-1500-/112019634829?forcerrptr=true&hash=item1a14e3fa8d:g:AIUAAOSwnNBXVc8Z&item=112019634829
Sure is pretty.
Sure is pretty.
Listing has tire specs as 325/50/20 which would only be a 32.8" tire not 35".
Not sure where you saw that listed. Under "Aftermarket Options" they have them listed as 325/50/r22 which would be 34.8 " x 12.8". In other listings they've also mentioned that if the buyer prefers 20 inch rims, they'll come equipped with 35x12.50s.
Regardless, I am in love with these trucks.
Edited by RHStansbury
Not sure where you saw that listed. Under "Aftermarket Options" they have them listed as 325/55/r22 which would be 34.8 " x 12.8". In other listings they've also mentioned that if the buyer prefers 20 inch rims, they'll come equipped with 35x12.50s.
No under aftermarket options it lists 325/50/22 and they even posted a pic of the tire showing the size...this does calculate out to a 34.8 tire though.
Edited by jrob56
It's 325/50r22 it says it and also the picture of the tire shows it. Also anyone can fit these under their truck but enjoy all the rubbing it will cause.
Sent from my SAMSUNG-SM-G930A using Tapatalk
