Called up the dealer and the first guy i talked to for a ready lift 2.25 level and alignment wanted 1200 dollars..... absolutely absurd. So then I had a friend who owns a body shop call the same dealer (parts guy instead of service guy) and they told him 475. I know everyone knows how dealers mark up everything but by upwards of 700 dollars?! Thats just wrong.
I was quoted $575 from my dealership for the same kit installed and aligned. There is a huge discrepancy in prices for levelling kits and installation! Just for a bottom of strut 3/4 inch thick aluminum spacer identical in shape composition and function (part only-different brand) range in price from $35 - $175! Installation quotes are equally diverse. The range in knowledge on this modification by professional installers is also quite incredible.
That's what I thought, but wasn't entirely sure, thanks. Unless someone can tell me, I guess I'll grab a magnet and climb under the truck.
Black is stamped steel - silver is aluminum..
So it looks like all the kits people have commented on thus far has the spacer above the strut mount. i tried to online chat with rough country but after i asked the question the rep ended the chat. so has anyone tried any brand spacer with the new stamped lower control arms?
One reason I haven't done it yet is because I don't want to void the warranty.. and I've heard on here that any suspension mods will void warranty for suspension.
It is on them BY FEDERAL LAW to PROVE the modification caused the damage, which is difficult for them to do so it shouldn't be an issue, especially if you have a good relationship with your dealer.
My dealership has a 2016 Silverado in their parts showroom with a standard 2" aluminum lower spacer with the stamped lower control arm. I forget the brand but it is discrete and looks great!
I have a 2.5" RC with the RC 2" rear blocked stacked on the stock block. The truck has a 1"- 1.25" rake and I like the stance since I tow a boat. But man this sucker rides pretty rough. I was going to remove the RC rear block and see if that would help but that would eave me too level for my taste. Do y'all think by me removing the front top spacer Ian's rear block it would help,that much?
Thanks
Edited by mmwest
Thanks
what kind of wheel tire combo are you running
Thanks
Never stack blocks...removed the original block and put the RC in alone. The trucks come with 2-2.5" rake from the factory, so raising the front 2.5" and the rear 1" with the replacement block will retain about 1" of rake. That's still not enough if you tow or haul anything, so look into Firestone RideRite Air Bags. It will change your life.
If the ride is too harsh for you, going from a 2.5" level to a 2" level is not going to change much. I found my truck road close to stock after the level, so I would put the blame on those 20" rims. Less rubber + more rim = harsher ride. It will only get worse if you go up to a stiffer LT tire.
If ride quality and lift is that important to you, than a level may not be your thing. You may need to go to quality 4" suspension lift or a small body lift.
Thanks
You have got to be kidding me, stacked blocks? Very unsafe, I would fix that ASAP, and never tell anyone you did that haha.
TGC 2.5" kit
33x12.50r22 Toyo MT
Fuel Hostage 22x11 -24
Front still sits a bit lower than then rear, only rub in reverse at full lock
5CF68855-4C34-41B7-9B5A-AF93F081DF0D_zps
I know,I know!. This was a dealer installed third time screw up (long,long story) and this time I'm moving on to a local shop. Going to definitely remove the stock block and go from there.
Ahh I see. Definitely never get any work done st that dealership
It is not difficult for a dealer to show a modification caused an issue with something. What is difficult is a person showing it didn't cause an issue when the dealer/and/or/GM showed it did. Happens more often than you think, especially when those that actually engineered and designed the vehicle are called to look at it and say otherwise; don't you think they would have the best idea?
If spacers are put in and a ball joint or CV axle fails, pretty easy to call out. Now trying to explain how a spacer caused a radio failing yeah, not going to happen. But the guy mentioned a spacer causing suspension warranty problems which is no where near out of the realm, so lets not go spreading false information...
CMP, as BCM noted it has to be directly caused by the mod, so while it can cause suspension warranty issue that part has to be the cause. It won't immediately wipe out your suspension warranty, it can just do parts of it if a failure happens and that was the cause. Wait until the warranty is up if you are worried. Either way most suspension fixes aren't ridiculously expensive like trying to replace an engine after a tune was on it and caused the failure.
Good luck, I personally am waiting until the stock tires are gone and going up. By then the warranty should be done (though I will still have the powertain) and it will be on my regardless.
Tyler
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 811 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
