I have stock 275/55/20's and the 2" rc spacer and it rides just like it did before the spacer. Perfect amount of lift for a level IMO.
theres a guy in my area with the 2.5 rc kit and hes running 285/65/20 with the stock 20" wheels. looks really good. does anyone else have this setup? any rubbing issues?
I will be running 20x10 with 305s I'll let you know. Quite a few other people have ran the same setup with barely rub on liner.
If I have the 2 inch leveling kit on my 2wd.......
Can I stack leveling kits on it and be ok scenes it's 2wd????
I have the 2 inch on the bottom which makes it level now but.... I wanna add the 3 inch on top of the coil and the 2 inch block in the rear and clear a wider rim this should only make the truck sit 1 inch higher in the front
Edited by Devinc
i installed a 2.5" leveling kit and now interested in upgrading the shocks, I spoke with a Bilstein rep and he told me that he doesn't recommend installing Bilstein 5100 with a leveling kit. He said they do not have any shock for my application. anyone heard of this?
Finally got around to getting the RC2.5 installed on my truck.
Waiting on the new wheels to be finished getting drilled and then will take another picture.
Before: 595327548fdfd7ddf4dbf9889b187ea4.jpg
After:
Same setup I've had on mine for 28k miles (since new). Couldn't stand the low riding no ground clearance truck look. Removed the front airdam (valence) and the rear splash guards. Total change in look and height appearance. What wheels you going for?
Got my RC 2.5"/1" leveling kit & BFG AT KO2 275/65/20s installed today. Love it
Man that looks really good!
I have RBP Glock (20x10) (305/55/20 Toyo AT2s on the way. Just waiting for them to drill them and send them out.
Edited by Wazbe
So here is the beast.... 2016 Stamped control arms 2wd 295/55r20 2.25 ready lift, tire hit and rub on sway bar..... going to 285/55r20
Edited by Catman5906
i was just about to ask guys about getting some shocks I have the RC 2.5 lift I was under the impression the 4600s where the ones to go? I'm trying to smooth out the ride when going over bumps and railroad tracks since there is one right by my house
I am running 305/55R20 on stock rims and there is incredibly slight rubbing on the felt and on the control arm at full lock with a 2" level. Not enough for me to actually do anything about at this point.
That would mean there would be a lot more rubbing with the 12.5" width as the ones I have are more like 12"
Can u post some pics? I want the same setup but I have +18 wheels. Do u have the g2 xl? How's mileage?
Mileage has suffered a bit. I would estimate ~2MPG loss.
Edited by Havvkeye
What is the offset on your wheels?
    TopBo
    TopBo
  • Who's Online   5 Members, 0 Anonymous, 1,696 Guests (See full list)
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
