Here's mine with 20x9 Mavericks and 295/55 Toyos, RC 2" in the front only
What kinda gas milage are you getting now man?
Did you have to make any changes to the body lift for it to work? I have a 17 and called Zone Friday with a response that the 14-15 body kit won't work on the 17. But, it's the same body style as yours.
Sent from my SM-G930R7 using Tapatalk
I actually had to make fewer modifications. The bumper does not have to be modified, only the bumper mounts on the truck. The only real difference was, I needed to notch the frame (where the e-brake cable passes through) more than the instructions state.
Finally got the leveling kit installed this past weekend. Looks good, should've done it sooner, a lot sooner.
Edited by 15BlueSilverado
Slightly off subject but i have a stock 2015 1500 LT. I want too put 22x12 inch rims on it. I was wondering if this would work and what the max tire size i could put on?
Finally put in rear blocks and bags.
2" front RC level
2" rear blocks
20x9+15 wheels
275/65-20 ko2's
No rubbing.
How would 295/60/20 fit on a 2016 Sierra Denali 1500 with a 2.5 RC level?
I dont know if there is any definitive answer for this, but how high can you go on a level with bilstein 5100 IF you get aftermarket UCA?
Mine are adjusted to the 2nd from highest setting, with 1.25 top spacer (netting about 2.5") and 1" higher in the rear (5100s also)
I know they say never go above 2.5 on a level or your ball joints will hate you -
---- My question is - WITH aftermarket UCAs, can i go to that top setting on the bilsteins, yielding about 3.25" in the front without having any issues? If so, is there anything else i would need to do (besides obviously an alignment)?
I had a 2" kit (front only) put on when the crap stock tires were ready for replacement. Up sized the tires to 285/55r20 Falcen AT3's. No problems rubbing at all, rides great. Wish I did this a long time ago.post-171580-0-60474000-1491776134_thumb.jpg
Edited by Dandizzle1371
Theoretically you could, but you're going to bottom out your shocks a lot quicker since they're not extended travel shocks.
Upgrade to an extended/lifted version of the 5100 and you should be fine w/ aftermarket UCAs.
Finally bit the bullet last week on tires. I ended up going with the Falken Wildpeak A/T3W's, and I will say in person they look better than expected. For the price, its hard to argue against them. They are very quiet and smooth, and the truck rides exactly like it did with the stock tires.
I went with the 305/65/18s because 285s look so tiny on these trucks. They measure 33.6x12, and somehow I dont rub at all with zero trimming and a 2" level. Here are before and after pics. I will eventually post better pictures, because these dont do it justice. It looks beefy in person.
C6679838-0AD1-444A-B887-9DF634183BCE_zps
C19D3885-5663-4E54-B49F-1A732A5E6C1C_zps
8907C925-1FD9-4BD9-AC96-95D02731B9C2_zps
9A16E782-89B3-424F-9BF3-0F5C5381F265_zps
C183AB6C-232F-4086-A648-9A597D5CBB28_zps
Edited by rawalters117
Those look awesome!
2" RC front level
XD Grenade 820 wheels 20x9 +0 offset
Falken wildpeak at3 tires 305/55/20
Edited by Criscone
2" RC front level
Truck looks great, did you have to any trimming or do you have any rubbing going on with the new setup. Looking at doing a similar setup on my truck.
Thanks,
Bob
    Policeoff01
    Policeoff01
  • Who's Online   5 Members, 0 Anonymous, 771 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
